March 29, 2026, 11:08:08 AM *
Author Topic: One of the part time drivers did a bad thing to a bus  (Read 789 times)
« on: January 17, 2019, 04:50:54 PM »
Put DEF into the diesel tank.
We were told it not only crystallizes but is very corrosive and if not removed quickly enough it results in the WHOLE fuel system having to be replaced. That seems to be the scenario for this bus.  Shocked
The bus is only 2 years old.
« Reply #1 on: January 17, 2019, 05:41:24 PM »
I had to look that up. I thought Diesel Exhaust Fluid was like Timken muffler bearings...
NewValker
VRCC# 36356
Oxford, MA
« Reply #2 on: January 17, 2019, 05:57:57 PM »
DEF...another genius idea brought to you by government.
Last generation of diesels had a regeneration feature to cut emissions.
We just dropped 8k on each of our two 2008 trucks to replace the entire system that became blocked and the trucks wouldn’t go over 20 mph.   uglystupid2
Craig
Turns out not what or where,
« Reply #3 on: January 17, 2019, 06:04:51 PM »
I have two diesel VWs - one a 2000 New Beetle, the other a 2015 Golf. The Golf also needs DEF - it gives you notice about "1500 miles" before it runs out. No DEF - car won't run. And before you ask - my 2015 has had it's emissions repair work completed.
DIGGER
« Reply #4 on: January 17, 2019, 08:26:03 PM »
At my car mechanics shop recently I saw what looked like a brand new Ford Dually diesel with the entire cab and bed sitting off to the side.....just the drive train there .   I asked what the deal wS and he said someone put Def in the fuel tank.   Destroyed the entire fuel system.    Said it was a $15,000 fix.
« Reply #5 on: January 17, 2019, 08:31:44 PM »
DEF is ammonia and distilled water. It's function is to clean the catalytic converter. Without it. deposits clog the cat and the exhaust is plugged up.
NewValker
VRCC# 36356
Oxford, MA
« Reply #6 on: January 18, 2019, 02:23:09 AM »
Sandy, that is exactly what the regeneration feature was supposed to do for the cat. When it didn’t work, the driver didn’t know until the truck stopped running and it was 8k to repair.
Craig
3W-lonerider
Shippensburg Pa
« Reply #7 on: January 18, 2019, 04:00:56 AM »
We have customers that continue to put diesel in the def tank. Turns into a pink cottage cheese.
New tank and def head for a jlg telehander is 2 grand.
baldo
Youbetcha
Cape Cod, MA
« Reply #8 on: January 18, 2019, 04:18:32 AM »
We have new GPU's for our aircraft. Same thing, someone mixed it up. Luckily it was discovered before any harm was done. Looks like some sort of education campaign would have been very helpful. I'd never heard of it until I saw these power units.
« Last Edit: January 18, 2019, 04:20:37 AM by baldo » Logged
« Reply #9 on: January 18, 2019, 04:59:53 AM »
They need to make the nozzles for diesel and DEF different to the extend that it would be terribly difficult if not impossible to mix them up, let alone ad the wrong fluid to the wrong tank.  Right now both are round holes, and some are located right next to each other.  With the generally clueless population we have in the world, this will continue to be an issue.  Also the stupid info symbols manufacturers use instead of words, this will continue to be an issue.   Another crisis averted by our government looking out for us. Had they not intervened, I'm sure the world would be covered in diesel soot by 2030.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #10 on: January 18, 2019, 05:08:42 AM »
SO, what vehicles are supposed to use def? Never mind, looked it up.  Smiley
« Last Edit: January 18, 2019, 05:22:40 AM by indybobm » Logged
So many roads, so little time
VRCC # 5258
3W-lonerider
Shippensburg Pa
« Reply #11 on: January 18, 2019, 05:20:00 AM »
in the industrial side of it.
all diesels over 94 horse need to have def.
personally i would'nt give you 2 cents for any vehicle that has to have def fluid.
« Reply #12 on: January 18, 2019, 06:12:25 AM »
We have onsite tanks for diesel and DEF.
The DEF fuel line has a smaller diameter than the diesel so fits nicely into the diesel opening.  Cheesy
What is annoying is that the bus in question has diesel fill on one side and DEF on the other.
However the buses that take DEF DO NOT have DEF marked by the filler cap. Something I suggested to the school as soon as the problem was mentioned.
« Reply #13 on: January 18, 2019, 06:23:57 AM »
Was this an obvious malicious act or a simple lack of understanding the bus maintenance requirements?
A malicious act deserves one response, the other makes me wonder who in the heck is in charge of driver training and ensuring maintenance on the buses.   What part of bus maintenance is a driver responsible for?  If it's a lack of training then blame the supervisor and take appropriate action.
Rams  crazy2
« Reply #14 on: January 18, 2019, 06:55:51 AM »
Rams  crazy2
I would guess probably the second. If this is the second time the same driver has done this - then the problem is clearly with them.
« Reply #15 on: January 18, 2019, 09:00:20 AM »
Rams  crazy2
I think a little bit of everything apart from malicious.
