December 31, 2025, 09:52:17 PM *
Author Topic: starter switch  (Read 995 times)
CMA_Carl
« on: January 23, 2019, 07:06:43 PM »
When I turn the ignition key on, the bike tries to start! Without pushing the starter button. I took the starter switch apart and found a broke wire so i ordered a new starter switch harness. what say you?
if i push the kill switch... it does not try to start and i can check the new turn signals and LED highway lights.
RonW
Newport Beach
« Reply #1 on: January 23, 2019, 10:25:22 PM »
those tiny wires are difficult to resolder, if that's the deciding factor for replacing the entire unit. I would buy an Interstate clamshell if you later add taller risers, the throttle cables will need more slack.
2000 Valkyrie Tourer
« Reply #2 on: January 24, 2019, 04:32:37 AM »
That's a new one, never heard of that symptom before.
If you bought this,
https://www.partzilla.com/product/honda/35020-MZ0-670?ref=f034d0ba4ba13dceea17c00b217a8d2df15a73f6
you should solve it.
Which wire was broken?
« Reply #3 on: January 24, 2019, 06:06:55 AM »
If you bought this,
Hook, Either I'm confused or you are...He found a broken wire at the starter switch.  How can buying a new turn signal housing help?
« Reply #4 on: January 24, 2019, 06:17:05 AM »
Opps, yeah Jeff, it's me. Embarrassed
Wrong switch
https://www.partzilla.com/product/honda/35013-MZ0-000?ref=f034d0ba4ba13dceea17c00b217a8d2df15a73f6
