March 29, 2026, 06:45:30 AM *
Author Topic: Any garage door gurus here?  (Read 1848 times)
« on: January 26, 2019, 09:30:55 AM »
Leave for work around 5.30am. It's dark and cold (normally) Press clicker in car and garage door closes.
Come home around 8.15am It's light and cold (normally) Press clicker in car and garage door opens
Walk into house and press door switch and door closes.
Leave for work around 1.15pm. It's light and cold (normally) Press clicker in car and garage door WILL NOT CLOSE.
It closes about 2 feet and opens. If I don't release the door clicker it still wont close.
Walk into house and press and hold door switch and door closes.
Come home around 5.15am It's light and cold (normally) Press clicker in car and garage door opens
What can be happening to stop the door closing when I leave in the afternoon???
« Reply #1 on: January 26, 2019, 09:39:02 AM »
I'm no guru. But there are a few times a year when the sun hits my sensors just right and won't let it close.
Moonshot_1
« Reply #2 on: January 26, 2019, 09:55:02 AM »
Are we talking about a single event or one that is continuous like every day?
Maybe you need to change batteries in your car "clicker". Low battery can do strange things.
Mike Luken
Cherokee, Ia.
« Reply #3 on: January 26, 2019, 10:06:46 AM »
80% every day.
New battery in clicker a month ago.
« Reply #4 on: January 26, 2019, 10:10:31 AM »
Based on info available, check the door sensors anytime it doesn’t work. They could have been hit and pushed, knocked slightly out of alignment. Or just go ahead and loosen them and get as close to center of alignment range and see if you have any more problems. Torsion springs could also be loosing some tension and causing a problem that will only get worse. Most operators have a lift force adjustment too, which you don’t want to max out but you could see where it is sitting now. Go ahead and disconnect the door from the operator with the pull rope and check the doors operation manually. It shouldn’t want to fall or fly up from any position along its travel. Best I can offer for now.
Moonshot_1
« Reply #5 on: January 26, 2019, 10:35:22 AM »
Was this occurring prior to the new battery? If not,  change the battery again.
Can you swap clickers from the house to the car?
If everything is as you described, that the garage door otherwise works fine except for your afternoon episodes, I would be leaning towards Meatheads thoughts. It seems odd that the problem occurs at only a particular time of day. The only conceivable common event would be the sun. Either your sensors are being triggered by the sun or from a reflection of it, like off your windshield.
Mike Luken
Cherokee, Ia.
« Reply #6 on: January 26, 2019, 01:00:50 PM »
No sun on sensors when door is  functioning/not functioning.
Only have one clicker.
I left the house at 2.15pm today. Door wouldn't close. Came back at 3.15pm door wouldn't close. That's with me with car in garage using clicker and then using the wall mounted closer.
Had to force it to close.
Garage door doesn't get sun at this time of the year.
Just checked it at 4.50 pm and it closed.
« Reply #7 on: January 26, 2019, 01:39:41 PM »
that is odd a few hours earlier and does not work,  then 2 hours later works.
I had similar issue Thursday morning but was BITTER COLD ONLY in the morning.  It has happened before in frigid temps only I had NO light on house remote by inside door to house in garage and light did not come on due to probably sensors on unit blocked and froze solid since was -15 out.  I waited a few seconds thinking darn it,  going to have to manually open door to leave but lights on unit popped on and so did the light on the wall so pushed button and worked.  BUT,  got into my car after OUT and darn car remote did not work to close it and neither did my outside 4 button push code still guessing FROZEN solid.  So, had to go back to wall unit inside garage that was lit up and push button and walk outside OVER the sensors.
Is it COLD OUT NOW where you live??  That could be the issue, but doubt it if 2  p.m. or so during day?
If not your sensors, then probably your circuitry is going bad in hopefully just the remote and not the head unit of the circuit board in the garage door opener itself.  My old Stanley opener from 1993 gave out finally 2 years ago having to go to Menards and get a belt drive Chamberlain unit is quieter and has a nice APP cell phone download so you can close or open and check if open/close right from your cell phone, pretty neat and unit can be put up yourself in one day or so but 2 people come in handier all under 200 bucks.  Motor/unit has a lifetime warranty as well and so if unit goes bad, I get a new one for free unlike Stanley opener I had which also had a lifetime warranty but went out of business several years ago.  Once a business is no longer in business selling that unit and got bought out or went bankrupt,  a lifetime warranty is useless.    Who knows,  maybe Chamberlain will not be in business 20  years from now either???
« Reply #8 on: January 26, 2019, 01:56:30 PM »
At 2:15 or 3:15 did you check to see if the little led lights at the sensor on both sides were lit? Usually one is green and the other amber. If they were lit it’s not the sensors at fault. Important to eliminate that issue as a possibility first.
« Reply #9 on: January 26, 2019, 02:22:01 PM »
I did not today but did Thursday when it happened. Grrrrr. Both lights were shining happily.
« Reply #10 on: January 26, 2019, 02:24:32 PM »
And my stoopid Android phone just decided to remove ALL THE APPS I had installed and put some weird crap on the home screen.
AND I HAVE A STINKING COLD.
It's a wonderful life.
Now to find out how to restore factory settings and then reload all the apps. Oh joy.
Beardo
Regina, Saskatchewan Canada
« Reply #11 on: January 26, 2019, 02:34:42 PM »
What he said.
When you close it manually, is it binding at all?  It could be requiring too much force for the opener, it might be thinking something is obstructing it.
« Reply #12 on: January 26, 2019, 02:45:14 PM »
What he said.
But how would that happen at one time but not the other 2 times each day.? Conundrum.
« Reply #13 on: January 26, 2019, 02:50:48 PM »
There is a small tear in the space time continuum that is sucking all your radio waves into a black hole that only opens wide enough to affect your operator in the evening hours after a full moon, probably best to just move again or take the door down and live with a carport.
« Reply #14 on: January 26, 2019, 02:55:31 PM »
Too much stuff for critters to play with to have a car port.
« Reply #15 on: January 26, 2019, 02:56:42 PM »
I want to know how long before my head is empty as I have Niagara Falls coming out of my right nostril. And that's with taking cold medication.  Evil
EDIT
https://www.straightdope.com/columns/read/1246/how-does-my-nose-produce-so-much-snot-so-fast-when-i-have-a-cold/
« Reply #16 on: January 26, 2019, 03:32:39 PM »
I’m a big proponent of NyQuil, but I throw away the little cup that comes on the cap and just turn it up and gulp it down. Not a cure but it lets me get some sleep. When my faucet is running, I haven’t found anything to really shut it off.
« Reply #17 on: January 26, 2019, 03:44:12 PM »
I'm useless on electronics and electrical.
But if it was me, I might leave my car out and my bike in, in case it decides to never open again... without a repairman (or a front loader).   I mean, while getting it figured out, plan for the worst.
When you do that, the worst rarely happens.  But....
« Reply #18 on: January 26, 2019, 04:43:59 PM »
If it continues,  maybe if replacing batteries does not work in remote and the sensor lights are on as should be,  if you can buy another remote for 20-30 bucks tops,  give that a try?    If house remote works in your garage by the door and the car remote does not,  probably your car remote?
« Reply #19 on: January 26, 2019, 05:40:03 PM »
« Reply #20 on: January 26, 2019, 05:40:40 PM »
I can open it manually  cooldude
« Reply #21 on: January 26, 2019, 06:15:55 PM »
Woo Hoo.
Phone back 100%
Dunno how I did it but it's all back apart from messages.
DGS65
Time enjoy wasted is not wasted time
Nanuet, NY
« Reply #22 on: January 26, 2019, 06:34:18 PM »
This sounds like a sensor issue!
Some units will flash the lights to tell you that something blocked the beam to let you know why it didn't close correctly.
« Reply #23 on: January 26, 2019, 06:55:16 PM »
Mr. Head has it right. If you can reverse the sensors, you'll fix the problem. The receiver is seeing too much sun.
« Reply #24 on: January 27, 2019, 06:21:06 AM »
According to Britman the sensors aren’t subject to those conditions.
« Reply #25 on: January 27, 2019, 06:45:59 AM »
But maybe his sensors are going bad, or slightly out of alignment.
« Reply #26 on: January 27, 2019, 07:42:31 AM »
Could be, as I suggested a realignment before, but if the leds are lit it indicates they are operational. Might be worthwhile to check their mounts to make sure they are tight but would not answer the intermittent operation at a given time.
baldo
Youbetcha
Cape Cod, MA
« Reply #27 on: January 27, 2019, 08:25:53 AM »
What he said.
I think your new house is electrically haunted.
semo97
Texas
« Reply #28 on: January 27, 2019, 08:39:50 AM »
My sisters neighbor had the same door opener code as hers. And both doors would do strange things. Until they observed each others and asked about there code, changed code and all was good.
I would rather have a runny nose then a plugged drain  and sinus headache.
« Reply #29 on: January 27, 2019, 08:40:34 AM »
Gravitational pull is stronger at 4:15 pm  Smiley
da prez
Wilmot Wi
« Reply #30 on: January 27, 2019, 09:43:13 AM »
Go back to basics. Service , lubes and adjust the door properly.
In the closer , there are bearings that operate the chain or cable or belt. If they are worn , it binds the drive. Properly adjusted , pull the release and see if the door will lift with very little effort. If so , the problem may be in the opener.
   Please send billing info for tech support.
            da prez
« Reply #31 on: January 27, 2019, 09:45:23 AM »
            da prez
Done that and the door lifts as easily as a garage door should.
« Reply #32 on: January 27, 2019, 09:52:41 AM »
Confined to home today and of course the garage door is going up and down like an elevator in the Empire State Building.
I took the clicker outside and the door closed.
« Reply #33 on: January 27, 2019, 11:10:16 AM »
It goes up and down all on it's own?
Unplug it.
Perhaps you need to look into an exorcism (for the house).   Grin
« Last Edit: January 27, 2019, 11:12:11 AM by Jess from VA » Logged
indybobm
Franklin, Indiana VRCC # 5258
« Reply #34 on: January 27, 2019, 11:42:51 AM »
Had this happen to me years ago. Problem was caused by a lack of lubrication on the rollers. Garage door mechanism sensed that two much current was required to close the door. There is a current adjustment (small screwdriver) on the unit mounted to the ceiling. I turned the current limit adjustment up and lubed the rollers, problem solved.
So many roads, so little time
VRCC # 5258
« Reply #35 on: January 27, 2019, 12:40:41 PM »
I had to check the sides of the doors and found the doggone culprit a few months ago. It could be as simple as a piece of a leaf or (the technical term) schmutz on the side of one of the 2 sensors. In my case it was a tiny stem from a weed caught in the side of the door about 10" off the ground
Can you go online and get a clicker for that setup for a few bucks if the problem continues.  There should be a part # for it in the operating manual (assuming you can find it)
bassman
« Reply #36 on: January 27, 2019, 02:01:09 PM »
EDIT
Ever try a Nettie pot or NeilsMed to clean out the ole snot locker.   Won’t necessarily stop the drainage but I’ve found some satisfying relief using them in the past.
« Reply #37 on: January 27, 2019, 02:15:08 PM »
I'll check the adjuster.
Lubed door/rollers etc only a month ago with garage door lube.
« Reply #38 on: January 28, 2019, 01:58:40 AM »
Release the door safety emergency at the top and run the door up and down a couple of times. It should be easy with no binding.
With the door disconnected run the door opener up and down at the times there would normally be a problem.
Bypass the safety eyes at the connection to the door opener or move them to within about a foot of each other.
Check or replace the batteries on the remote or check with another remote.
Change the frequency if you can on the door and the remote. Good to do once in awhile for security also.
Check all the anchoring points of the opener and the opener slide itself for loose bolts or misalignment.
Check the wiring to the garage door opener from the switch or door button and sometimes the switches have a setting or switch on them to turn off the ability to open and close the garage door, check that also.
Check the wiring on the opener sometimes I have seen something as simple as one strand of wire touching another terminal.
« Last Edit: January 28, 2019, 02:19:09 AM by Robert » Logged
« Reply #39 on: January 31, 2019, 06:36:21 AM »
I increased the "close" power by about a quarter turn when I got back from the morning school bus run.
It also closed at 9 at about 27F.
I'll report back if this makes any difference.
Door closed correctly at 5.30 this morning at 25F leaving for work.
