March 29, 2026, 09:15:49 AM *
Author Topic: Clutch Fluid leaking underneath bike  (Read 647 times)
thevalkdude
« on: January 28, 2019, 09:25:32 AM »
I have a Clutch Fluid drip under my 95 Valk.
What is or would that be? Cannot find any diagrams or parts list for that section of the bike.
I added fluid at the top and bled it - worked great but when I got back from my ride - I put a piece of clean cardboard underneath and sure enough there is a drip. Seems to be at a small cover where the line goes in.
Thanks for your help.
cc
« Reply #1 on: January 28, 2019, 10:02:07 AM »
Slave cylinder rebuild
https://www.ebay.com/i/223174301264?chn=ps&ul_ref=https%253A%252F%252Frover.ebay.com%252Frover%252F1%252F711-117182-37290-0%252F2%253Fmpre%253Dhttps%25253A%25252F%25252Fwww.ebay.com%25252Fi%25252F223174301264%25253Fchn%25253Dps%2526itemid%253D223174301264%2526targetid%253D484887847669%2526device%253Dm%2526adtype%253Dpla%2526googleloc%253D1013962%2526poi%253D%2526campaignid%253D1497794122%2526adgroupid%253D56281259685%2526rlsatarget%253Dpla-484887847669%2526abcId%253D1139466%2526merchantid%253D101982943%2526gclid%253DEAIaIQobChMIuOL08JKR4AIVishkCh3aSwZYEAQYECABEgLyz_D_BwE%2526srcrot%253D711-117182-37290-0%2526rvr_id%253D1837708301837%2526rvr_ts%253D95ced9401680a888b282adf1fffffda4
« Reply #2 on: January 28, 2019, 10:16:55 AM »
That's the most likely culprit.
I changed mine out.
It cost more than a rebuild (can't remember how much but it wasn't a lot) and was easier to do.
SCain
Rio Rancho, NM
« Reply #3 on: January 28, 2019, 10:21:08 AM »
95 Valk?  Wink
Sounds like the clutch slave, personally I would order the replacement parts from Honda, you may not need the piston, but I would replace any seals and sealing washers. Don't forget to replace the seal that the pushrod goes through since you are there, dab a little grease on the pushrod.
There was a lot of threads about this subject several months back, do a search and you will find lots of info.
« Last Edit: January 28, 2019, 10:22:46 AM by SCain » Logged
Steve
Dave Ritsema
South Bend IN
« Reply #4 on: January 28, 2019, 11:05:46 AM »
95 Valk?  Wink
I wondered if I was the only person that noticed that.  Grin
VRCC 2879
Lake City Honda Warsaw IN
« Reply #5 on: January 28, 2019, 12:24:08 PM »
95 Valk?  Wink
I just figured he got an early prototype  Smiley
