January 30, 2026, 02:07:10 AM *
Author Topic: Aeromach offering Velocity Stacks!  (Read 6134 times)
GreenLantern57
Hail to the king baby!
Rock Hill, SC
« on: November 20, 2009, 05:41:27 PM »
http://www.aeromachmfg.com/V_Stacks_Honda_Valkyrie_p/am-2410hc.htm
Aeromach is offering the Velocity Stacks. Looks pretty good.
DFragn
« Reply #1 on: November 20, 2009, 07:21:48 PM »
If you want to put these on an Interstate. Here's my method...
These are the same billet stacks that I cut a "V" opening to accommodate the I/S pods. I did not want to start bending pod engine guard mount tabs to reposition the pod to fit with stack installed. It's a clean and virtually invisable modification method and does not create a tweaked pod position.
Aeromach' stacks are CNC machined from a solid block of billet aluminum, not cast aluminum like the other guys.
I used a Dremel cut-off wheel, fine filed the cut & polished the cut on a polishing wheel. You'd be hard pressed to see where the chrome ends, especially if I had filed the cut and sanded a little better. The chrome has not chipped or peeled at the cut edge. I don't know for sure, but I doubt I would have had the same results with the other's cast units. The cast units, I imagine, would be more brittle and possibly prone to fracturing and/or breaking.
« Last Edit: November 22, 2009, 06:33:02 AM by DFragn » Logged
GreenLantern57
Rock Hill, SC
« Reply #2 on: November 20, 2009, 08:48:53 PM »
Looks good! Nice job!
Jack B
Two Rivers Wis
« Reply #3 on: November 21, 2009, 04:34:03 AM »
I'm thinking about ordering a set for my bike. I know the Aeromach are better than HDL but looking at the price of $255 & $170 ($199 -15%off)
I think I'll save some $$ this time around
Let’s RIDE
skromfols
You only go around once
Valley Springs, Calif
« Reply #4 on: November 21, 2009, 06:39:39 AM »
Do Velocity stacks improve performance or are they only for looks ?
Stan
DFragn
« Reply #5 on: November 21, 2009, 06:47:43 AM »
Aesthetics only.
Momz
ABATE, AMA, & MRF rep.
« Reply #6 on: November 21, 2009, 01:33:15 PM »
You can lie to them HD folks and say they add about 50-60 hp.
ALWAYS QUESTION AUTHORITY!
DFragn
« Reply #7 on: November 22, 2009, 06:34:22 AM »
You certainly could if you have BigBF's screens. They make it look like there are filters under them.
BTW the screens also drain water from the stacks quite well.
skromfols
« Reply #8 on: November 22, 2009, 06:53:46 AM »
It's too bad that they don't contribute to performance.  My Valk has enough bling, and the Harley guys already think I have way too much hp.
Stan
Farther
Quimper Peninsula, WA
« Reply #9 on: November 22, 2009, 05:34:55 PM »
I like safety chrome but not at that price.
~Farther
