November 14, 2025, 05:22:56 AM *
Author Topic: 97 and 99 wheels  (Read 1009 times)
dancnman
Houston, Texas
« on: February 04, 2019, 04:34:45 PM »
Will the wheels from a 97 standard work on a 99 interstate if I use the original (99) rotors?
Thanks!
Reality is that thing which does not change simply because I choose to ignore it.
« Reply #1 on: February 04, 2019, 05:03:28 PM »
All wheels will interchange if you use the corresponding rotor...
indybobm
Franklin, Indiana VRCC # 5258
« Reply #2 on: February 04, 2019, 05:49:29 PM »
To use the 97 wheel on a 99 IS, you have to use the 97 rotor. The 99 rotor will not work.
So many roads, so little time
VRCC # 5258
indybobm
« Reply #3 on: February 04, 2019, 06:11:41 PM »
What I said in my previous reply applies to the rear wheel only.
As  for the front wheels, all 97-03 front wheels use the same rotors.
VRCC # 5258
indybobm
« Reply #4 on: February 04, 2019, 06:35:02 PM »
Had to move from the phone to the computer
As for the front wheel – 1997 Valkyrie front wheels have a 1J cast on the hub. 1998-2003 have a 2J cast on the hub.
1J front wheels use a smaller bearing than the later 2J wheels.
All Valkyrie front wheels (both 1J & 2J) use the same front brake rotor.
As for the rear wheel - there are basically two models. The early wheels have a 1J cast on the left side in the area inside of the brake rotor. The later wheels have 2J cast in that area.
1997-1999 Std/Tourers have the 1J wheel, All IS and 2000-2003 Std have the 2J wheel.
1J wheels take the early brake rotor, 2J wheels (whether polished or not) take the later brake rotor.
You cannot just go by the year of your bike, the wheel might have been changed at some point. Look for the 1J or 2J.
VRCC # 5258
« Reply #5 on: February 05, 2019, 04:33:28 AM »
+1. For the rear wheel. The rotor must be correct for the wheel. If a '97 wheel has the thinner inside rotor, that wheel will fit all 97-03 Valkyries. Same for the newer wheels with the thicker rotor.
SCain
Rio Rancho, NM
« Reply #6 on: February 05, 2019, 06:15:36 AM »
You can use the 99 rotor on the 97 wheel (Rear) it will require a shim to keep the rotor from scraping the caliper.
I believe the shim goes between the wheel spacer and caliper bracket.
Steve
dancnman
Houston, Texas
« Reply #7 on: February 05, 2019, 01:59:51 PM »
Many thanks for the most excellent information.
