November 14, 2025, 05:21:20 AM *
Author Topic: 90° intake runners to mount air pods horizontally  (Read 1257 times)
RonW
Newport Beach
« on: February 07, 2019, 09:29:02 PM »
These kits are on eBay, here. Dunno if the stock carbs will fit, but the vendor includes their own carbs in the kit. Even an air pod. $40 each.
« Last Edit: February 07, 2019, 09:30:51 PM by RonW » Logged
2000 Valkyrie Tourer
3W-lonerider
Shippensburg Pa
« Reply #1 on: February 08, 2019, 02:35:33 AM »
By the looks of that carb. It would require a cable to go into the top to operate it. So to use 6 of those you would need to make 1 thottle cable into 6 cables.
RonW
Newport Beach
« Reply #2 on: February 08, 2019, 08:11:28 AM »
Well, at least the tank won't be the way with the horizontal design. If the Valk carbs actually fit, they should sell just their intake runners.
da prez
Wilmot Wi
« Reply #3 on: February 08, 2019, 01:53:40 PM »
  No bolts on a Valk carb, Hose clamp both ends.
                                            da prez
LB
2003
Upstate South Carolina
« Reply #4 on: February 08, 2019, 02:46:31 PM »
Can't use the OEM carbs... these are sold by and shipped from China … I wouldn't put a $20.00 carb on my lawnmower.
Steel cowboy
Spring Hill, Fl.
« Reply #5 on: February 09, 2019, 04:40:20 AM »
I bought the same set up, for a Chinese scooter project. I had to re drill the main jet because it ran to lean. Why not just pick up a set of manifolds for a Valkyrie from fleabay and have a welding shop cut and re weld them facing out. If done properly the stock carbs would face outward with minor plumbing and cable re routing.
2001 black interstate
2003 Jupiter Orange wing
« Reply #6 on: February 09, 2019, 05:48:53 AM »
Is this idea just for looks ? I’m not really understanding the strategy.
F6BANGER
Albuquerque NM
« Reply #7 on: February 09, 2019, 06:42:52 AM »
Carbs reversed has been done before. A guy named TrickRick and his bike Scorch.
https://www.youtube.com/watch?v=DIIkRwNU6JY&feature=player_embedded
indybobm
Franklin, Indiana VRCC # 5258
« Reply #8 on: February 09, 2019, 08:29:30 AM »
The inlet to the Valkyrie carbs is not at a 90 degree angle.  If you attach them to a 90 degree intake manifold as pictured the carbs would be at the wrong angle. If you want to carbs to face out, just turn the stock inlets 180 degrees.
So many roads, so little time
VRCC # 5258
« Reply #9 on: February 09, 2019, 09:01:08 AM »
I wonder where that bike is now.
