November 20, 2025, 03:25:39 PM *
Author Topic: Need Help Troubleshooting  (Read 4446 times)
Tundra
2014 Valkyrie 1800
Seminole, Florida
« on: November 21, 2009, 06:26:50 AM »
I need help trouble shooting.
Yesterday when my clock hit 86 miles from full tank, she acted like she was running out of gas. I switched to reserve, didn't help.
I limped into a gas station in the middle of nowhere (Hardee County), gassed up, said a little prayer and on my way, problem gone!
88 miles down the road, same problem. Switched to reserve seemed to clear up a bit, then same thing. Limped in for gas again, I was not empty either time, 2.5 and 2.6 gallons to fill her up. This time I turned around to head home, I wanted a direct route, so went 301 to the crosstown expressway (mistake) Most direct, although nowhere to pull over. Performance and speed decreased, couldn't get over 42mph, cars passing me at 80mph. Stopped for gas again when I safely could, at 90 miles on the clock from last fill, road home problem free, 6 miles. WTF? ???
I was supposed to meet up with TJ at the Log Cabin today (too far to push a Valk)  Sad  It appears the problem consistantly appears at 86-90 miles from last fill-up.???
Note: Last maintenance performed was shimming needles and installing Interstate springs. I have ridden since this, problem free and re-checked my work (diaphrams and sliders properly seated)
TIA-for any input.
« Last Edit: November 21, 2009, 06:35:55 AM by Tundra » Logged
John U.
Southern Delaware
« Reply #1 on: November 21, 2009, 06:43:18 AM »
It sounds like it could be a failing petcock or more likely a cracked vacume  line to the petcock. If the vacume is reduced the petcock won't open fully but with a full tank of gas, the head pressure is enough.
Good luck
John
DFragn
« Reply #2 on: November 21, 2009, 06:46:50 AM »
If you've installed a fuel filter - remove it to rule it out.
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #3 on: November 21, 2009, 07:28:31 AM »
No fuel filter, I rebuilt my petcock earlier this year. I don't remember, but at least 3-4 months ago. Also replaced the petcock vacuum line at that time. Thanks.
  The milage from fill-up, to when this problem occurs is clost to the same, could that indicate anything???
« Last Edit: November 21, 2009, 07:30:11 AM by Tundra » Logged
Bone
« Reply #4 on: November 21, 2009, 07:54:00 AM »
Running out about the same usage each time.
That might indicate the bottom of the tank screen plugged.
I haven't read here of that ever happening. Just a thought.
Warlock
Magnolia, Ms
« Reply #5 on: November 21, 2009, 07:59:05 AM »
Sounds like petcock problem or screen. I had problems like that and I could back off the throttle and it would run fine. If I tried to run faster it would act like it was running out of gas. Problem was the petcock. So I installed electric fuel shut off and done away with the vacuum and no problems since.
David
Scott from FL, now in Maine
Augusta, Maine
« Reply #6 on: November 21, 2009, 08:11:03 AM »
Hey Tundra, another thing to note is the tank vent, but the only way I know to test it is another ride. Ride until it happens again and then open the tank and close it to see if it clears up. You could be forming a vacuum in it. If that seems to fix it, try it again, but put a tie wrap in the cap before you close it to see if the problem goes away for good. If so, you'll know exactly what the problem is. Good Luck and keep us posted!  Cool
junior
new hampshire
« Reply #7 on: November 21, 2009, 12:03:27 PM »
for chits and ha ha's try this and e-mail back the results please: when it acts up and your still going ( pull the clutch in and let it idle for a few seconds) ans see it it wont pick back up and run normal, cause mine is doing the same thing i think i have narrowed it down to water lock from the ethenol in the gas, we have 10% here in NH.
thanks, junior
« Reply #8 on: November 21, 2009, 12:16:29 PM »
thanks, junior
When you pull the clutch and idle, the manifold vacuum goes way up. This will open the petcock due to a higher vacuum. During the "clutch pull", more fuel will fill the bowls and off you go again. It's still a petcock problem.
six2go #152
Ft. Wayne, IN
« Reply #9 on: November 21, 2009, 12:48:40 PM »
My '98 was doing the exact same thing back in the early Summer. My petcock had been rebuilt so I thought it was a vent tube issue. Nope! Each time it died, I could get it restarted by opening the fuel cap to allow air in, then it would run for awhile longer. Try rolling up a dollar bill or something similar & close the fuel cap on it so as to keep the cap from sealing completely. Mine would act normally if I did this. We checked the petcock, and even though it had been rebuilt, it would not hold a vacuum. Installed a Pingel and problem is gone.
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #10 on: November 21, 2009, 04:10:47 PM »
Thanks for the reply's cooldude I'll keep you posted.
AussieValk
Gold Coast, Australia
« Reply #11 on: November 21, 2009, 06:53:28 PM »
I know this has been in here before, but I'm too lazy to look. Can someone put up the link for the Pingel fuel tap please?
Thanks.
John U.
Southern Delaware
« Reply #12 on: November 22, 2009, 05:47:08 PM »
Thanks.
This will do it I believe: http://www.pingelonline.com/
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #13 on: December 01, 2009, 03:47:05 AM »
OK, today's the day. I will be looking at the old girl today, checking the vacuum line for kinks and proper ventillation.  Checking the tank screen for dirt/ obstruction.  Checking the petcock for proper operation. Will post my results for future refferance. I'm hoping for the easy, inexpensive way out for a change!
Crazyhorse
Hattiesburg, MS
« Reply #14 on: December 01, 2009, 05:59:32 AM »
   Can the OEM petcock be converted to work as a manual petcock?
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #15 on: December 01, 2009, 06:36:22 AM »
I'm not the expert here...I believe I saw somewhere that you can cut a hole out of the diaphram. Which would eliminate the vacuum operation. So If this is true, then yes you would be strictly manual on and off. ???
  Has anyone done this? Happy with your results?
« Last Edit: December 01, 2009, 06:37:54 AM by Tundra » Logged
« Reply #16 on: December 01, 2009, 06:41:27 AM »
CH,, the OEM petcock can be converted to manual and the instructions are probably some where in the archives if not shoptalk.. But, the time it takes to do that[I did it once] isn't worth it cuz it can still dribble when shut-off.. I don't think I've heard of anyone having a problem with a Pingle..
Bone
« Reply #17 on: December 01, 2009, 06:50:22 AM »
This was posted a week or so ago. The RM site for the belly tank tells us how to convert to manual.
1.1. Disassemble petcock valve by removing 4 screws.
2.2. Remove diaphragms from center slug.
3.3. Reinstall fuel diaphragm backwards (upside down) from original position.
4.4. Reassemble petcock valve without spring, spring seat and slug. (should only have 2 diaphragms.
5.5. Replace petcock valve back into tank in original position.
http://www.rmworksinc.com/files/Belly_tank_instruction_manuel-pdf2.pdf
« Reply #18 on: December 01, 2009, 08:50:47 AM »
I would strongly urge anyone considering to modify their existing stock petcock to not mess with it.
That stock petcock is extremely unreliable and will fail you absolutely, especially if you modify it.
An aftermarket petcock is the best way to achieve what you want from your petcock.
Pingel and Golan come to mind as a good aftermarket petcock.
Just sayin'.
Rocketman
Seabrook, Texas
« Reply #19 on: December 01, 2009, 08:58:24 AM »
Pardon the stupid question, but what do you mean by this?
Farther
Quimper Peninsula, WA
« Reply #20 on: December 01, 2009, 09:29:46 AM »
I don't think your question is stupid.  Looking forward to the answer.
~Farther
X Ring
VRCC #27389, VRCCDS #204
« Reply #21 on: December 01, 2009, 09:33:26 AM »
The ONLY stupid question is the one not asked.   cooldude
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #22 on: December 15, 2009, 04:49:30 AM »
OK I give... I'm sick of working on this bike...again. I know you all can't be wrong, I'm going Pingle. Still having the same petcock problems, rebuilt twice. New #6 vacuum, new screen, checked tank venting. Still the same crap! The Pingle is cheaper than the Honda OEM!!! $92.00 polished aluminum, $101.00 chrome and $106.00 for OEM.
  Question, can I leave my engine hangers on and still operate the Pingle? I know this has been asked before also, what do you all cover the hole in the engine hanger with? Any thoughts on dressing it up a little?
TIA Wink
« Last Edit: December 15, 2009, 04:51:33 AM by Tundra » Logged
Farther
« Reply #23 on: December 15, 2009, 06:52:25 AM »
Have you checked and possibly replaced the tank vent line?
~Farther
Rocketman
Seabrook, Texas
« Reply #24 on: December 15, 2009, 07:20:49 AM »
TIA Wink
I don't have engine hangers, and am not very familiar with them, but I can't imagine reaching in to the valve with hangers on there.  These: http://www.valkyrieblingandmore.com/pienhaco.html say they're built for use with the Pingel.
To move the valve selector switch, you have to reach under the tank.  After using it once or twice, it becomes second nature, so that I don't think about it anymore.  But, with something blocking the hole, it would be difficult.  Not sure how Valkyrie Bling fixed the problem for the unit linked above.
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #25 on: December 16, 2009, 02:50:03 AM »
I heard milage changes, or actual reserve milage can/will change with the Pingle do to the shorter fuel pickup tube?  Is this a factor, or something to be concerned with? Does the Pingle come with a new screen and o-ring? Or even use a screen and o-ring?  Thanks all, just trying to get everything I need before my conversion. What about number 6 vacuum line, just remove and cap it?
MP
North Dakota
« Reply #26 on: December 16, 2009, 05:06:41 AM »
I have the Pingal, waiting to be put on.  I also have a new OEM petcock.  When I put them side by side, there is only a slight difference to the top of the tube.  Now, on the OEM, the screen continues up quite a ways above the tube top, while on the Pingel, it is only a little ways.  Is not the top of the tube where you normally take in gas?  Does not look like much difference on mine.
Also, the screen on the Pingel is MUCH coarser.  IMHO, if you use the Pingel, you NEED an additional inline filter, or you are just asking for particles to get stuck in the carbs.
MP
"Ridin' with Cycho"
