November 14, 2025, 05:21:12 AM *
Author Topic: Found during desmog  (Read 1489 times)
Fixjet
Belvidere, IL
« on: February 20, 2019, 01:51:04 PM »
Not sure if the PO was trying a version of desmoging but I found a bolt in the par valve hose from the air box and no vacuum line to the par valve.  #3 & #4 carb capped off.  I'm glad I decided to desmog and will do it correctly.
https://www.flickr.com/photos/168456054@N05/47114303062/in/dateposted-public/
« Last Edit: February 21, 2019, 04:56:07 AM by Fixjet » Logged
« Reply #1 on: February 20, 2019, 06:42:34 PM »
Your link isn't working. The PO was probably trying to eliminate the vacuum hoses which may have been leaking.
john_berry
« Reply #2 on: February 21, 2019, 05:31:53 AM »
I have a California bike. If I plug my hoses like that, the bike wont run hardly at all. I think those two line vent the carbs. When I desmogged I put a piece of screen over those two hoses so they would vent but yet keep the bugs out.
john_berry
« Reply #3 on: February 21, 2019, 05:34:12 AM »
If you do have a California bike then you'll have more ports to plug on the carbs. If I remember correctly, I had to plug 2 ports per carb.
Fixjet
Belvidere, IL
« Reply #4 on: February 21, 2019, 08:12:22 AM »
It's not a Cal bike, I just had not heard of anyone just blocking the Par hose to the airbox and the 3 & 4 carbs.   Everything else was normal stock installation.  I'll finish it up right.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #5 on: February 21, 2019, 08:22:10 AM »
Actually, I think the left hose goes to the Secondary Air Control valve, this gets removed during a normal desmog. The hose on the right goes to the Crankcase Storage Tank.
So many roads, so little time
VRCC # 5258
trout dude
Hammond Louisiana
« Reply #6 on: February 21, 2019, 09:30:37 AM »
it looks like a stealth desmog kit   When you pulled the hoses off the par valves did they have pins in them?   If so it was desomog already with that kit i have them and they work well Redeye made them Hope this helps Dennis
Fixjet
Belvidere, IL
« Reply #7 on: February 21, 2019, 10:53:57 AM »
No, all 6 where open, just looks like the PO wasn’t real sure how to do it.  I have the shiny kit so it will get done correctly.
Fixjet
Belvidere, IL
« Reply #8 on: February 21, 2019, 10:57:21 AM »
Your correct, my bad it is the hose to the SACV.
indybobm
« Reply #9 on: February 21, 2019, 06:37:44 PM »
I will take a leap here and  say that as long as the reeds are not broken, it should be ok to just remove the vacuum hoses from #3 & 4 intakes and plug them.
VRCC # 5258
