December 31, 2025, 09:35:39 PM *
Author Topic: I think I'll wait till it warms up a touch before going much further  (Read 1146 times)
Ken aka Oil Burner
Mendon, MA
« on: February 20, 2019, 03:32:56 PM »
Waiting for my Partzilla order to show up so I can repair my driveshaft and pinion cup. I thought I'd pull the tank and start my de-smog procedure. The thermometer in my unheated garage showed 26 degrees this afternoon. Just getting the hoses to release from where they were connected was a chore, since the "flex" in the rubber was not present today. Getting the airbox out was a real hoot. I can say with certainty that the airbox lower will be headed in the house a few hours prior to the hog tie procedure before it gets installed again.
On a side note, I'm removing the K+N air filter and putting a stock element back in. The thin foam "pre cleaner"; is that stock or did that come with the K+N? I didn't see it in the part picture on Partzilla of the factory airbox components.
« Reply #1 on: February 20, 2019, 04:20:07 PM »
Ugh working in the cold... I'm in SC, but my "unheated garage" is the outside.
Would your garage heat up some with a couple of (safe) space heaters?
There's a lot of different opinions about the K&N air filters, I like OEM the best too.
« Last Edit: February 20, 2019, 04:23:49 PM by hubcapsc » Logged
Ken aka Oil Burner
Mendon, MA
« Reply #2 on: February 20, 2019, 04:27:57 PM »
I have a couple space heaters, but when I try to use them, the heat goes straight up and out of the garage, into the roof (no ceiling). I thought about adding one to enclose the space, but I store stuff on the rafters and hang things here and there, too. It's a single bay attached to the house (ranch style with a breezeway in between). I tell myself that my new shop will be heated/cooled. When I'll ever get it built, I don't know. Still hopeful, though.
« Reply #3 on: February 20, 2019, 04:48:26 PM »
Yeah, you're doomed without a ceiling... it looks like it goes up to 50 or so
in some places in Massachusetts a day or two next week...
-Mike "spring is on the way..."
mello dude
Dayton Ohio
« Reply #4 on: February 20, 2019, 04:54:32 PM »
I can really identify with not working in a cold garage, I am in the same spot...
For a bit of inspiration, I like to watch this video - "Waiting out Winter"  - Vimeo file.
https://vimeo.com/59380598
Give me the hope to end winter...  cooldude
« Reply #5 on: February 20, 2019, 04:56:19 PM »
A roll of visqueen stapled to the rafters is relatively cheap and works pretty well.
« Reply #6 on: February 20, 2019, 05:02:18 PM »
The thin foam is not OEM, goes with the K&N. Don't forget you will need the rubber gaskets for your air box when going back to OEM.
« Reply #7 on: February 21, 2019, 08:54:58 AM »
Unless Mendon has specific codes against it, you can build a shed up to 200 sq ft w/o a permit.  No frost protection foundation needed.  That's 10x20, or 12x16, pretty good size for a bike shop.  Insulated walls & ceiling and a small electric heater would warm it up nice.  Just saying. Smiley
One of my bikes came with a K&N.  I changed it back to OEM.
