November 14, 2025, 03:25:52 AM *
Author Topic: Pilot screw size  (Read 1041 times)
1NorthRyder
Elliot Lake, Ontario, Canada
« on: March 02, 2019, 08:44:51 AM »
I need to replace my pilot screws as the ends a slightly buggered up and not easy to turn. I have had trouble finding out what the correct size is. The bike is a 2000 Interstate. I believe the correct OEM size is 35mm and some folks have increased the size to 38mm. I,ve googled it but haven,t found a clear answer. Thanks in advance for your help.
1NorthRyder
« Reply #1 on: March 02, 2019, 09:42:54 AM »
Been reading more and believe I am wrong (yes I am man enough  to admit it, but don’t tell my wife) about the size, the 35 & 38mm I believe are the jets. I just want the screw, spring and washer that you lightly seat and then turn bake about 2 turns.
mark81
Cincinnati Ohio
« Reply #2 on: March 02, 2019, 10:24:49 AM »
The pilot screw is not a jet so that may be some of your confusion.
https://www.partzilla.com/product/honda/16016-MAS-670?ref=4f689702f5326aabebc627ea30468c281d13ef67
This is what you need
1997 Honda Valkyrie
1981 Honda CB750 Custom
1NorthRyder
« Reply #3 on: March 02, 2019, 11:18:42 AM »
Thanks Mark, I found that part # just before you posted so all is good as long as I can get them delivered quickly.
rug_burn
Brea, CA
« Reply #4 on: March 02, 2019, 01:46:19 PM »
Guys-  help me out here a little-  are you discussing those screws on the carbs that adjust the main needle mixture?
On my '97 the heads are circular with a kind of small flat, like a d-shape,  i think they were changed later.  That's what you're talking about, correct?   How do you turn these to adjust them with the carb on the bike?   Is there a tool for that?
I made a tool to turn mine, and set all the carbs a little leaner than they were (about 1/8 turn) because the exhaust always smelled a little rich, but just how do you adjust those inaccessible screws without pulling all the carbs?
...insert hip saying here..
Forge
San Antonio, TX
« Reply #5 on: March 02, 2019, 04:11:28 PM »
My oem D screws were badly rounded so I replaced them with the K&L slotted screws.
« Reply #6 on: March 02, 2019, 05:20:30 PM »
When I pulled my carbs to clean some years ago, I used a Dremel tool with a cutting blade and turned them into something I could adjust with a flat blade screwdriver. Just don't hold them with bare fingers while cutting....unless you like blistered fingers.  Wink
1NorthRyder
« Reply #7 on: March 03, 2019, 01:14:02 AM »
Yup, those are the ones. There is a tool from Motion Pro for adjusting when on the bike but still a pain in the ass.
« Reply #8 on: March 03, 2019, 10:53:06 AM »
honda uses those screws on many of their carb bikes
honda tool to get, it was org listed for the cbr900.
it has a flexible spring head. been using it for yrs.
07MMA-MT3010B WRENCH PILOT SCREW
