March 29, 2026, 06:44:12 AM *
Author Topic: Difference between Europe and US color codes?  (Read 1242 times)
Täpi
« on: March 09, 2019, 10:23:54 PM »
Hello fellow riders!
I'm a proud owner of a 1998 Valkyrie to where im now installing a fairing to reduce wind fatigue on myself. The fairing came unpainted and now is the time to get some paint on it.
I've been to a couple paint shops here in Finland with the codes:
Y137M Pearl Ivory Cream
PB255M Pearl Coronado Blue
Unfortunately the responses that i've gotten from them are that they are unable to make the paint with these codes so now i started wondering - is there a difference between US and Europe color codes?
« Reply #1 on: March 10, 2019, 01:40:17 AM »
http://www.valkyrienorway.com/COLORS.html
Looks like you have the correct codes
« Reply #2 on: March 10, 2019, 01:47:32 AM »
Or you can go here and look it up
https://www.colorrite.com
Andy Cote
Windham, Maine
« Reply #3 on: March 10, 2019, 05:08:55 AM »
When I had my National Cycle panniers painted to match my 97, the shop did not use Honda paint codes nor colorite brand paint.  They were able to mix a color that perfectly matched.
They also matched the tape pinstripe by sight and later from that supplier found a chart that matched to the Honda color chart for he stripes.
Point is IMHO a good body shop can match from visual and not be reliant on factory paint codes.
2015 Goldwing, basic black
Previously: 2000 Valkyrie Interstate, 1997 Valkyrie Standard, 1988 GL1500, GL1200 Standard, GL1200 Interstate and many other Hondas
« Reply #4 on: March 10, 2019, 06:37:47 AM »
they should be able to match it up or darn close.  I know when I had to have my newer 2014 hyundai sonata lower rocker panel painted from the salvage yard black to car color of gray,  the paint code the body shop had from factory was good up to a point.  Apparently,  that SAME paint code had about 7 color combinations of that particular gray used in 2014 and he layed them all out (sample chips) comparing to the gray color of my car and 2-3 were nearly identical, but 3-4 were way off not matching.  I had to get the wife involved since he asked me MY opinion and I told him I was color blind, so let me get the misses.
Alberta Patriot
« Reply #5 on: March 10, 2019, 07:20:29 AM »
My interstate is the reverse of the more common black over red color scheme. Do the same color code #'s still apply, or was the red modified for my bike?
Someone, a while back, posted a Valkyrie color scheme chart that listed all years and color schemes, but it did not identify the difference between the two opposite black/red schemes for the Interstate.
I was told there were only a few done in my bike's reverse color scheme. I'm thinking that because it is a Canadian Bike with metric speedo and Serial #...even more rare.
« Last Edit: March 10, 2019, 07:41:26 AM by 7th_son » Logged
da prez
Wilmot Wi
« Reply #6 on: March 10, 2019, 07:36:27 AM »
  When we first tried to match the strawberry and cream (the color discussed) by the Honda color number , the paint company indicated the colors were patented and could not be copied(?).
 We had a color scan done (at no charge) to get the codes. The match on my bike is as perfect as I am able to see. If you need the strawberry code , I can get it when I go to the shop. I do not have the cream code as I got rid of the can before writing down.
                                        da prez
« Reply #7 on: March 10, 2019, 08:31:35 AM »
The colour codes are for/from Honda. If you get the pain from them, then you're good to go.
But take those same "part numbers" to someone else, and they have nothing.
Colorite is your best choice. They give you the top coat and the base coat. This will match the OEM colour.
But as mentioned, any good shop can scan and custom match any colour. The question would be is it going to cost you more than just a stock colour off the shelf? Is the fairing far enough away from other colours that a slight difference won't be noticed?
Yes, it's a 2001, a different black over red ( Pearl Cheyenne Red with Gloss Black ), rather than the red over black ( American Red ). It is a factory colour, and along with almost all the IS colours, I like them a lot.
The years and colours are mostly here.
http://www.valkyrienorway.com/About%20the%20Valk%20NEW.html
Pappy!
Central Florida - Eustis
« Reply #8 on: March 10, 2019, 08:03:08 PM »
Since you have already gotten some great advice....Welcome to the site from Central Florida!
