November 14, 2025, 09:03:57 AM *
Author Topic: Turn Signal Switch Repair  (Read 892 times)
Fazer
« on: March 11, 2019, 09:38:23 AM »
I bent the metal slider inside the turn signal switch and have attempted to bend it back but in several attempts have not got it right.  Prevents the thumb lever from returning to center after operating the left turn signal.  Does anyone know where I can buy a replacement part--just the slider?  The entire assembly is available for $80, but I only need a small piece.
Thanks.
Greg
Nothing in moderation...
Valker
Wahoo!!!!
Texas Panhandle
« Reply #1 on: March 11, 2019, 10:26:33 AM »
I would look for someone who could 3D print one. They are NOT available separately. If you properly clean and lube the mechanism, they will last pretty much forever.
« Reply #2 on: March 11, 2019, 12:06:11 PM »
I would look at pinwall
SCain
Rio Rancho, NM
« Reply #3 on: March 11, 2019, 01:15:14 PM »
Either Pinwall or eBay, the Honda Shadow switch might be the same and cheaper, not sure just something to check out.
Steve
