December 31, 2025, 07:47:33 PM
Drive Shaft Assembly and Install
Topic: Drive Shaft Assembly and Install (Read 1154 times)
mrgeoff
My 99 CT..."Liahona"
Augusta, GA.
March 11, 2019, 06:07:55 PM »
I'm getting ready to remove the rear wheel again on my 1999CT(10,000mile check) and change out the Universal Joint and Boot too...The questions I have about this is as follows...
When I remove/install the Oil Seal on the Shaft (how far back will it go/ will it stop at a certain spot?...is there any special way to install the new one? (Tricks of the trade)
Do I use a flat bladescrew driver to get it seated?...
Does it just slide on easily or do I have to twist it till it gets to where it should be?...
Will it be seated properly when I finally install the shaft into the pinion cup?...
I just don't want to damage the rubber seal as I install it...!!!
The last time I had the shaft off every thing looked good but I want to replace the Oil Seal, Stopper Ring,
Spring, Washer, and Snap Ring along with the Yoke and Boot...This way I will feel better that it is done
properly...Or at least I know I have done it the best I can...!!! Wish me luck...and Thanks for all you do...!!!
mrgeoff/SANDMAN
Ken aka Oil Burner
Mendon, MA
Re: Drive Shaft Assembly and Install
March 11, 2019, 08:15:16 PM »
Let's see. To replace the seal on the shaft, you'll have to have the spring and hardware removed from the shaft. It fits right over the shaft until the point where it sits; it's larger there, and machined for the seal to be seated / placed properly. There is a "stop" area. Personally, I used a 1" box wrench and a small dead blow hammer to install mine, since I didn't have a suitable pipe handy.
If you're taking the u-joint out, I definitely recommend getting a new boot. It will be much more flexible than the old one, making a miserable job a bit less miserable.
I just did all of this for the first time, so there may be more input from more "seasoned" members, but that's about it. This forum has been a great resource for me as I learn about my Valkyrie.
https://www.amsoil.com/?zo=5889580
mrgeoff
Augusta, GA.
March 13, 2019, 04:17:10 PM »
Thanks Ken...
I will put your advise into my plans...I did get all new parts so I know that everything would be right...I will just take my time and say a good Prayer when installing the new boot...!!!
Geoff...!!!
mrgeoff/SANDMAN
=> InZane XXV
