November 14, 2025, 01:31:01 AM *
Author Topic: Saddle Bag Guards  (Read 1165 times)
greggh
OMAHA NE
« on: March 12, 2019, 04:38:00 AM »
Needing the 2 bolts that attach the guards with the back tube that crosses behind/under the rear fender.
Having difficulty finding the schematics that shows the Bag Rails for a 1998 Tour.
Any help is certainly appreciated.
Thank you Gregg
SCain
Rio Rancho, NM
« Reply #1 on: March 12, 2019, 05:21:50 AM »
I think the bolts are 6mm x 10mm long, they are a flanged head hex bolt. Valkyrie of Norway website has the installation instructions for the saddle bag guards.
Steve
« Reply #2 on: March 12, 2019, 05:27:23 AM »
http://www.valkyrieriders.com/shoptalk/Manuals/BagRails1.pdf
http://www.valkyrieriders.com/shoptalk/Manuals/BagRails2.pdf
« Reply #3 on: March 12, 2019, 06:13:10 AM »
And once you get those bolts, when installing with the little half clamps, they go on easier upside down than as shown in the instructions.
greggh
OMAHA NE
« Reply #4 on: March 12, 2019, 07:14:46 AM »
It's all installed,
Just missing 2 bolts that hold the back of the guards together with the cross bar behind the gender
« Reply #5 on: March 12, 2019, 07:50:14 PM »
If the link works, is 57 the one you're talking about?
https://www.procaliber.com/oem-parts?aribrand=HOM&arian=MOTORCYCLE#/Honda_Powersports/GL1500CFA_(99)_VALKYRIE_INTERSTATE%2c_USA%2c_VIN%23_1HFSC410-XA000001/SADDLEBAG/GL1500CF-99-A/14MBYXE1AMBY4F3900AC/y
greggh
OMAHA NE
« Reply #6 on: March 13, 2019, 06:20:38 AM »
Gordonv, the link did work.
The bolt needed is for the Bag Guards not the bag supports.
The furthest to back bottom rail connects to a bar that reaches behind the fender to the other guard rail.
There is a bolt 1 on each side connecting those sections of the Guards.
Thank you for the link tho.
« Reply #7 on: March 13, 2019, 07:25:13 AM »
The (Honda or aftermarket-copy) bag rails are not going to be shown in the OE parts diagrams.
It's possible the bolt referred to is the same size as what he needs, but only possible.
The correct bolt is listed in the above PDF Honda bag rail 2-page instruction sheet (1st page), but it's not easy to see which is the exact one needed from the schematic.  Is it #8 or #10?
« Last Edit: March 13, 2019, 07:28:02 AM by Jess from VA » Logged
SCain
Rio Rancho, NM
« Reply #8 on: March 13, 2019, 08:12:15 AM »
#10, 6mm x 12mm  long Flange Hex Bolt
Steve
longrider
Vernon, B.C. Canada
« Reply #9 on: March 13, 2019, 08:39:38 AM »
I think the bolts he is talking about use an Allen key and thread into the solid rod at the end of each side of the center section rear.  They would be 6 mm by about 10 mm long
greggh
OMAHA NE
« Reply #10 on: March 13, 2019, 09:42:59 AM »
Thanks all for the sizes
Will get them both to save the trip back if needed.
Thank you all again!!
