November 14, 2025, 09:03:53 AM *
Author Topic: Question about OEM Shocks  (Read 1592 times)
Fazer
« on: March 12, 2019, 08:58:38 AM »
I just bought a replacement shock on Ebay and noticed it's a little different from the one I am pairing it too.  My current shock is a Showa MZO-003 and the one from Ebay is MZO-A41.  Could the A41 be from an Interstate?  I only need to use during the 4-6 weeks my Progressives are being re-built.  Any problems mixing the two for the short term?  Both are the same overall length.
Nothing in moderation...
« Reply #1 on: March 12, 2019, 09:01:48 AM »
Check parts fishe.  But it sounds like one is for std and one is IS.  I would not mix
« Reply #2 on: March 12, 2019, 09:16:01 AM »
I borrowed Stanley Steamer's  Interstate shocks for a few weeks while
I was waiting for my Progressive 440s to be rebuilt. I can't imagine there's be a
problem having an OEM Interstate shock on one side and an OEM Tourer/STD
shock on the other... maybe set the Interstate one softer than the Tourer
one since Interstates are a little different because of the Interstate's extra
weight... you'll really appreciate your Progressive shocks when they come
back  cooldude
-Mike "just because I don't think it would matter doesn't protect you from a flaming death  Wink "
Avanti
Stoughton, Wisconsin
« Reply #3 on: March 12, 2019, 09:18:50 AM »
If the spring loads are not the same it could twist the swing arm. Bad news for safe steering.
I would not mix them either.
Ken aka Oil Burner
Mendon, MA
« Reply #4 on: March 12, 2019, 09:25:04 AM »
I was looking around on Partzilla. The 003 appears to be from a 1997 Standard/Tourer, and the A41 was on a 1999 Standard/Tourer. More than likely just an updated part, but likely same/similar spring rate. I think I'd run it.
https://www.partzilla.com/catalog/honda/motorcycle/1997/gl1500ct-a-valkyrie-tourer/rear-shock-absorber
https://www.partzilla.com/catalog/honda/motorcycle/1999/gl1500ct-a-valkyrie-tourer/rear-shock-absorber
Fazer
« Reply #5 on: March 12, 2019, 09:40:58 AM »
Thanks guys.  It's only for a short time.  Can't bear the thought of missing a month a riding in the spring.
nogrey
Nampa, Idaho
« Reply #6 on: March 12, 2019, 10:19:58 AM »
back  cooldude
I called progressive customer service today about getting a set of 440’s rebuilt. They said they don’t offer that service. Where are you getting yours done?
mark81
Cincinnati Ohio
« Reply #7 on: March 12, 2019, 10:22:39 AM »
Didn’t you just get the progressive shocks a few years ago?  I’d hope they last longer than that before a rebuild is due
1997 Honda Valkyrie
1981 Honda CB750 Custom
Fazer
« Reply #8 on: March 12, 2019, 12:04:44 PM »
No Grey--I called them and had to send a photo of the leaking shock and a copy of my receipt.  I bought them in August 2015.  They are doing this under warranty, I guess.
Mark--surprised me too.  Not that I over work 'em.
« Reply #9 on: March 12, 2019, 12:11:34 PM »
If you've ever had a swingarm off the bike in your hand, you'd know how stiff they are. Different shocks won't be noticeable. In the short term, use them.
« Reply #10 on: March 12, 2019, 03:31:05 PM »
Sorry for getting your hopes up... this was about eight years ago...
« Reply #11 on: March 12, 2019, 04:23:15 PM »
Agree. the Goldwing GL1500 uses unbalanced shocks.
