December 31, 2025, 06:11:39 PM *
Author Topic: Berryman B 12 - Just do it.  (Read 1390 times)
« on: March 23, 2019, 04:38:34 PM »
Bikes performance tends to diminish slowly over time unless something catastrophic happens.
2 tanks with Berryman B 12 and my bike runs like the ape got scalded.  cooldude
Rolls on from 2,000 rpm in fifth like a carrier launch.
I did about 50 miles this morning on the second tank in 2nd and 3rd above 3,000 rpm.
By about 150 miles into my 200 mile day the bike was flying.
Temp and low humidity could also have been a factor.
« Reply #1 on: March 24, 2019, 09:44:48 AM »
It was suggested, and I do it as much as I can, to buy gas from Chevron, so you get a little Techron in with your fuel, and keep your carbs clean, and the bike running nicely. On trips, it's which ever gas station is there, but I look for the Chevron first.
Then that 1/2 can of B-12 at the first new fuel tank of the year.
How much Berryman's to the fuel did you use?
« Reply #2 on: March 24, 2019, 10:04:39 AM »
As recommended. 1 oz per gallon. I also use ethanol free when possible.
« Last Edit: March 24, 2019, 05:05:00 PM by Britman » Logged
« Reply #3 on: March 24, 2019, 10:57:43 AM »
I've been using TC-W3.  keeps everything clean and most important the carbs lubed. Have seen a consistent 1-2 mpg improvement.
https://www.ls1.com/forums/f48/been-testing-oil-91206/
h13man
Indiana NW Central Flatlands
« Reply #4 on: March 24, 2019, 11:54:49 AM »
Berry B12 user also. 1/2 a can in the spring tank and every 2500 mi. thru the season as directed.
« Reply #5 on: March 24, 2019, 05:06:26 PM »
You're putting 2 stroke oil in the gas?
« Reply #6 on: March 24, 2019, 05:40:53 PM »
yes, but has to be the TC-W3 spec'd oil. put it in my diesel also. It works. read the pages 1-7 of the link to see the ratio that must be used.
« Reply #7 on: March 24, 2019, 07:56:14 PM »
No, no, no.  The cat gets scalded.  The ape gets raped.
(The cat seems eminently safer)  Grin
I
« Reply #8 on: March 25, 2019, 03:03:33 AM »
I
Sometimes I like a mixed metaphor.
« Reply #9 on: March 26, 2019, 08:06:17 AM »
I
Like does the Pope ѕhit in the woods...
« Reply #10 on: March 26, 2019, 08:39:22 AM »
I
not allowed to kiss his ring anymore.
