March 28, 2026, 11:07:51 PM
Corbin IS seat question
Topic: Corbin IS seat question (Read 734 times)
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
April 03, 2019, 03:23:25 AM »
Did Corbin ever make the two up one piece Interstate seat with a 5/8” x 5/8” slot for the passenger to use a Corbin back rest, my thought is when two up and the trunk is off the bike.
Re: Corbin IS seat question
April 03, 2019, 07:52:20 AM »
I had one of those concrete blocks on one interstate when I bought it. (Sold)
It had no slot in back of the
dual tour
I doubt if any did, but you could call Corbin and try to find out, or if they can retrofit one to your seat.
I suppose it might be possible to fab up a mount to the rear seat bolt that wraps around the rear of the seat, and holds a small pad.
April 03, 2019, 10:56:07 AM »
Wouldnt it be putting too much pressure on the fender ?
_Sheffjs_
Sarasota FL
April 03, 2019, 11:05:28 AM »
Quote from: meathead on April 03, 2019, 10:56:07 AM
No, as the stock Corbin (two piece) has this option for Standard/Tourer.
April 03, 2019, 11:54:43 AM »
Well, any seat that has a built in slot is reinforced inside the seat slot itself (so the stress is spread over the whole rear seat). If you fabbed a mount to the rear seat bolt alone, it could stress the fender at the bolt (unless you put a plate or something down there to spread out the stress of someone's back on the backrest).
ridingron
Orlando
April 04, 2019, 09:23:27 PM »
Mine just has one for the driver.
<a href="
https://m.maploco.com/visited-states/mine.php?states=AL-AR-AZ-CA-DE-FL-GA-KS-KY-LA-MD-MO-MS-NC-NM-NV-OK-PA-SC-TN-TX-UT-VA-WV
