January 30, 2026, 03:42:26 AM *
Author Topic: steering stem bearings  (Read 2767 times)
Doc X
« on: November 23, 2009, 05:33:00 PM »
How many have used All Balls tapered steering stem bearings? Do you like them and have any of  you had any problem with the All Balls bearing?
thanks,
Doc X
Warlock
Magnolia, Ms
« Reply #1 on: November 23, 2009, 07:31:15 PM »
thanks,
Doc X
I just installed a set in my Tourer. I think several has used them here. The only problem I have had is they sent me the wrong seals for my forks. Called them and they are sending me more.
David
« Reply #2 on: November 23, 2009, 07:43:53 PM »
I used them with no problems. Will get another set from them. Make sure you recheck the torque after a few hundred miles.
DFragn
« Reply #3 on: November 24, 2009, 07:33:39 AM »
I agree check the torque after a few hundred miles.
Also, the bible says to seat the bearings at somewhere around 32 lbs. then back to the final 12lbs. I found better seating at 65 lbs. and later discussed it with my service dept. and they said they seat 'em at 65-70lbs.
I decided to seat with a heavier torque because I was still having issues after the manuals 30 some seat value.
I've no problems at all now and am good to 100mph +.
X Ring
VRCC #27389, VRCCDS #204
« Reply #4 on: November 24, 2009, 08:36:56 AM »
Let me see if I have this right.  Initial seating at 65-70lbs then release and retorque to 12lbs.
« Reply #5 on: November 24, 2009, 08:42:31 AM »
Lady Draco used them and recommended them to me...
DFragn
« Reply #6 on: November 24, 2009, 12:18:13 PM »
Almost.
Seat the bearings at 65 - 70 lbs. and then work the forks lock-to-lock a dozen times. You'll feel the stem begin to loosen a little. Then back the torque down to 12-20 lbs. and turn the forks again. Repeat twice more and finally finish out at 12lbs.
I found later on I needed another 2 lbs. more to stabilize the forks at 85 mph +.
But start with the recommended 12 lbs. and see how she does. It could have been my torque wrench needs calibrating.
« Reply #7 on: November 24, 2009, 03:48:17 PM »
I noticed mine we loss when the front wheel was off. I replaced them about 4 months earlier!  Shocked Did not notice riding but got 2 rounds out of the nut.
art
Grants Pass,Or
Grants Pass,Or
« Reply #8 on: November 24, 2009, 03:52:50 PM »
Isn't there a special socket for the adjustment nut ? If so what is the pt.# of it? I have one I bought for a gold wing it is for a four slot castilated nut
Madmike
Campbell River BC, Canada
« Reply #9 on: November 24, 2009, 04:15:56 PM »
Anybody get the part numbers off of the replacement sets before they installed them??
« Reply #10 on: November 24, 2009, 05:41:14 PM »
I got the package up in the garage. It would be faster to look them up. I got mine at wingworx.com
« Reply #11 on: November 24, 2009, 05:44:16 PM »
I believe mine is 4 slotted also. Yours may fit. Don't rely on me tho!
Madmike
« Reply #12 on: November 24, 2009, 07:45:22 PM »
I looked at AllBalls and HDL to see if there were any measurements or bearing numbers but neither has anything but their own numbers.  If someone has a manufacturers number (NGK, SKF, FAG, Timkin etc.) it can likely be crossed over and local supply can be found.
I see in the manual that the lower bearing has more surface area than the top  one, suspect that it may be a high load bearing.
