December 31, 2025, 04:25:21 PM *
Author Topic: Progressive Shocks  (Read 1578 times)
dancnman
Houston, Texas
« on: April 04, 2019, 07:34:35 AM »
I called Progressive and they informed me the only shocks that fit my Interstate are the 412 or the 416. He couldn't tell me anything about any other model numbers and said those were the only 2 that would work.
I read on here that the 444-4221C Chrome 13" are being used on our (Interstate) bikes. Has anything changed? Will that shock still work without modification? Is that the shock to go with?
I need help.
Reality is that thing which does not change simply because I choose to ignore it.
« Reply #1 on: April 04, 2019, 07:47:25 AM »
444-4221C.  Those are the ones I'm using on my IS.  No complaints whatsoever, even two-up on Austone tires.  cooldude
dancnman
Houston, Texas
« Reply #2 on: April 04, 2019, 08:44:28 AM »
Thank you. I am ordering them.
« Reply #3 on: April 04, 2019, 08:57:32 AM »
I searched the board on 444-4221C ... lots of VRCC people have gotten them... I bet it
is the good choice...
dancnman
Houston, Texas
« Reply #4 on: April 04, 2019, 09:40:44 AM »
As I understand it, these are the Heavy Duty shocks. I weigh about 210, am I too light (haha) for these? Just asking......
« Reply #5 on: April 04, 2019, 10:53:19 AM »
The 4221s are fairly firm, but adjustable so you can find your sweet spot.  I like them about at about the halfway mark for riding two up on the taller tire, but I rarely bother with adjusting them when riding solo (90% of the time).  I'm about your weight.
Jersey
VRCC #37540
Southern Maryland
« Reply #6 on: April 07, 2019, 08:38:58 AM »
With 2up do you notice any additional scraping in normal curves/turning?  I did with the 13" Progressives and the Avid Envigor 205/60-16, which is about 1" less diameter than the Dunlop MTs.  Right now I'm riding on the Progressive 14" Air Shocks to add back that 1".  With 2up I can lean over far and don't scrape anymore.
Jersey
« Reply #7 on: April 07, 2019, 02:05:39 PM »
I did some scraping in corners when two-up with the peg lowering kit.  Didn't need the peg lowers so I took 'em off. We used to bottom regularly on 416 air shocks that came on my Tourer, but they were needing a rebuild and I didn't want to mess with that. I have 444s on both bikes.
« Last Edit: April 07, 2019, 02:11:43 PM by Valkorado » Logged
