January 30, 2026, 02:07:11 AM *
Author Topic: Brembo rear caliper for a Valkyrie on eBay...  (Read 2425 times)
« on: November 24, 2009, 10:20:28 AM »
Never heard of such a thing...
BonS
Blue Springs, MO
« Reply #1 on: November 24, 2009, 07:11:54 PM »
I couldn't find it, can you post a link? This is the Brembo mototcycle brake site: http://www.brembo.com/ENG/Motorcycle-Brakes/. Nothing specific for Honda let alone a Valkyrie.
« Reply #2 on: November 24, 2009, 07:19:05 PM »
http://cgi.ebay.com/ebaymotors/Rear-Brake-caliper-HONDA-Valkyrie-VT-VTX-VTR-VF-XR-XL_W0QQcmdZViewItemQQhashZitem439a8a4242QQitemZ290355561026QQptZMotorcyclesQ5fPartsQ5fAccessories
Rear Brake caliper HONDA Valkyrie VT VTX VTR VF XR XL ...
BonS
Blue Springs, MO
« Reply #3 on: November 24, 2009, 07:30:32 PM »
Absolutely has to be a case of simply adding the Brembo name to a casting. It's sourced from Thailand, the land of bad copies and fakes. It would be flattery to even call it a knock-off. I'm sure that Brembo never made a caliper with just a single piston on a side. But, if you like the Brembo name on a caliper for show then the price isn't bad at all - if it works!
BonS
Blue Springs, MO
« Reply #4 on: November 24, 2009, 07:34:43 PM »
Well, I'm going to correct myself. I checked out the Brembo site and the do say: "Floating calipers are available in versions with one and two pistons in diameters from 26 to 34 for single pistons and from 28/28 to 30/32 for two pistons. The applications are possible for disks with a diameter of 155mm to 330mm and with thicknesses from 3.5 to 8mm." So they do make single and double piston calipers for road bikes.
BonS
Blue Springs, MO
« Reply #5 on: November 24, 2009, 07:50:48 PM »
This is a link to a very similar one that is OEM for Ducati. https://www.harris-performance.com/website/acatalog/Original_Equipment_Calipers.html
The UK price is around $120, but it's not a knock off. I'd be very leery with products out of Thailand as I've seen our companies name cast right into parts that we never made or sold.  tickedoff
