December 31, 2025, 04:40:56 PM *
Author Topic: Rear brake pedal height  (Read 1008 times)
Randy52
SW Wisconsin
« on: April 19, 2019, 06:51:02 AM »
Want to lower height of rear brake pedal. Service manual only states a measurement of 3.4" on the threaded rod ( between rod hole and rear mounting hole).  Can I just adjust the rod length? I realize that the switch would also have to be adjusted.
« Reply #1 on: April 19, 2019, 08:59:30 AM »
I think you would have to relocate the entire mounting plate for best results
WintrSol
Florissant, MO
« Reply #2 on: April 19, 2019, 10:31:32 AM »
The rod adjustment does allow for a limited range of pedal adjustment; the number in the manual sets the recommend height of the pedal.
longrider
Vernon, B.C. Canada
« Reply #3 on: April 19, 2019, 01:22:58 PM »
For those of us that have installed floor boards the pedal needs to be raised a bit.   You should be able to adjust it so as to be comfort for you
Randy52
SW Wisconsin
« Reply #4 on: April 19, 2019, 08:58:31 PM »
Went ahead and shortened rod length to lower pedal and then adjusted brake light switch. Worked out good. Thanks for replies.
