November 29, 2025, 11:46:16 PM *
Author Topic: altenator  (Read 1102 times)
flash2002
Montreal, Que
« on: April 22, 2019, 06:13:53 AM »
Hi guy's, does anybody know what size the alternator bearings are, I think mine might be due to be changed. The bike is a 1998 CT. I'm not sure, the noise might just be the brushes but from the sound it might be the bearings, using a stethoscope . I would like to have the bearings on hand when I take it apart just in case. Thanks
« Reply #1 on: April 22, 2019, 06:23:54 AM »
http://www.valkyrieforum.com/bbs/index.php/topic,73080.0.html
I replaced the rear bearing at 52k miles, it was not smooth rotating, but didn't have any noise.
picked up at Napa, actually better bearing than oem.
flash2002
Montreal, Que
« Reply #2 on: April 22, 2019, 11:45:14 AM »
I took a look at the bearings for the alternator, is it possible the rear bearing is selling for between 50 and 80 bucks, or am I looking at the wrong one, the front one is about 20$ or so.
pancho
Bonanza Arkansas
« Reply #3 on: April 22, 2019, 11:54:25 AM »
I think there is a mixup somewhere with the price you are coming up with flash. Bearing sizes are international, if someone has a rear bearing, there should be a number on it which will cross to all manufacturers bearings that are the correct size, Japanese, Chinese and American.
« Reply #4 on: April 22, 2019, 11:56:45 AM »
NAPA #6000-2RSJ    2017 price 22.95
RWhitehouse
« Reply #5 on: April 22, 2019, 04:24:30 PM »
Bearings are standard/generic sizes. The napa part # is also the standardized nomenclature.
Napa has massive markup on bearings. Get them from a reputable ebay seller or any number of online outlets. Napa wanted $30 for a skf wheel bearing, got them online for $7. Honda parts fiche usually gives the standard bearing nomenclature in addition to the Honda #. Or can always just measure id, od, and thickness and search to determine what the standard size is. Always in metric/mm. The - 2rs suffix refers to the type of seals/shields.
« Reply #6 on: April 22, 2019, 04:37:06 PM »
make sure they are not fake bearings your getting for $7.
http://www.bearing-news.com/skf-destroys-15-tons-fake-bearings/
pancho
Bonanza Arkansas
« Reply #7 on: April 22, 2019, 05:42:23 PM »
Wow,,,  might want to go with Timken bearings for awhile, that sort of puts  a damper on eBay skf bearings for me...
https://www.ebay.com/itm/TORRINGTON-Timken-6000-2RS-Deep-Groove-Ball-Bearing-10-mm-ID-26-mm-OD-8-mm/222710607785?epid=4008881675&hash=item33da962fa9:g:pRQAAOSw3WxaAfYe
« Last Edit: April 22, 2019, 05:47:30 PM by pancho » Logged
flash2002
Montreal, Que
« Reply #8 on: April 23, 2019, 01:10:06 AM »
Sorry guy's my mistake, it's the front bearing that is expensive. If I'm looking for a good quality bearing they are not cheap.
« Last Edit: April 23, 2019, 01:29:12 AM by flash2002 » Logged
« Reply #9 on: April 23, 2019, 05:42:58 AM »
it is other manufacturers also, that was just one article.  there are some articles out there how to identify a fake or real SKF bearing. I brought skf front wheel bearings off ebay but they were the real deal.
