December 31, 2025, 04:40:50 PM *
Author Topic: FM Antenna  (Read 1145 times)
Fazer
« on: April 22, 2019, 10:02:24 AM »
I have a Woody's fairing with an Infinity PV-250 radio that Glenn was good enough to install for me.  It has a wire antenna looped around inside the fairing.  AM comes in fine, but FM reception is weak.  Is there any type of booster, or different antenna that might aid reception?
Greg
Nothing in moderation...
« Reply #1 on: April 22, 2019, 11:33:20 AM »
I have no problem with the wire atenna that came with my woody’s. But they do make a booster you can add in.
Bagger John - #3785
« Reply #2 on: April 23, 2019, 06:23:23 AM »
Dakota Digital offered one (which I have in my custom I/S's fairing) and IIRC Sierra sells a booster too.
RipVanWinkle
« Reply #3 on: April 23, 2019, 08:36:58 AM »
http://www.tunetrapper.com/index.html
this is the one i use and i have no issues.
« Reply #4 on: April 23, 2019, 10:28:52 AM »
We have a few good custom radio-stereo shops.  I stopped in one day and got a lot of good information and advice from them.
« Reply #5 on: April 23, 2019, 06:18:44 PM »
Here is another supplier of goodies.
https://www.rightchannelradios.com/collections/cb-antennas
Fazer
« Reply #6 on: April 24, 2019, 07:56:14 AM »
Thanks for the suggestions.  I have discovered the problem, now to find a fix.
As it turns out, the reception is fine unless I turn on my LED driving lights.  Seems there is some noise or interference.
I am guessing there is some way to shield the cable to prevent.  Next time I have the tank off, I will get to the wiring.  Maybe I can simply re-route away from the radio wiring.
Any thoughts about cable shielding would be appreciated.
Greg
3W-lonerider
Shippensburg Pa
« Reply #7 on: April 24, 2019, 08:24:15 AM »
Go on amazon and order rfi chokes. They will clip on you led wiring and iliminate the interference.
I put those on my led headlights and got rid of all the interference.
Bagger John - #3785
« Reply #8 on: April 24, 2019, 09:11:46 AM »
A common-mode ground loop will cause this problem.
The root cause, though, is the LED driver. They're pulse-width-modulated, in order to keep the average power going to the LEDs within limits...but the waveform is a square wave and is rich in RF harmonics.
Best thing you can do is to choke the heck out of any leads going to the lamp assemblies (as a previous poster pointed out) and look at using a single-point ground system for all the electrics. This includes the antenna booster (if installed). There's really nothing you can do to the "output" side of the LED controller to kill the noise without affecting the circuit operation.
Fazer
« Reply #9 on: April 24, 2019, 09:42:24 AM »
Thanks guys--Just ordered a bunch of "chokes."
3W-lonerider
Shippensburg Pa
« Reply #10 on: April 24, 2019, 01:18:31 PM »
if your led's have a module in line like my headlights did. i put a choke on each side of that black box module.
