December 31, 2025, 04:39:33 PM
Leaky radiator hose
Topic: Leaky radiator hose (Read 947 times)
dbyer58
Leaky radiator hose
April 22, 2019, 12:49:53 PM »
Hello
I noticed my upper radiator is leaking where it connects to the engine. I ordered a new hose and plan on putting it on soon. Is it as easy as it looks? Drain the antifreeze...pull off the radiator (easy I hope) and install the new hose. Anything I should know before I start this job? Thanks all!!!
Re: Leaky radiator hose
April 22, 2019, 01:31:30 PM »
Yes, you should know this is not uncommon and usually fixed by just tightening that clamp. No need to drain the fluid, no need to remove the radiator. Just take out the one bolt at the top, tip it forward and reach in with a socket extension and tighten the clamp.
April 22, 2019, 02:17:08 PM »
^^^^^^this
indybobm
Franklin, Indiana VRCC # 5258
April 22, 2019, 05:58:34 PM »
Using a 1/4" rachet and long extension I was able to tighten the clamp without removing anything. I did epoxy the socket on first to keep it from disappearing.
So many roads, so little time
VRCC # 5258
April 22, 2019, 08:52:12 PM »
Plus if you start it and let it warm up it will more than likely stop leaking without tightening the clamp.
dbyer58
April 22, 2019, 10:30:55 PM »
.I never noticed it leaking untill i took it out this spring after winter storage. only a couple drips per day . Still havent started it yet. Ill give all the suggestions a try. Thanks
=> InZane XXV
