December 31, 2025, 04:41:10 PM
Need advice on trailer tongue length.
Topic: Need advice on trailer tongue length. (Read 1034 times)
April 22, 2019, 07:59:27 PM »
I'm gathering parts and material to build a one-wheel trailer for the Valk to tow. I've been doing some research on the tongue subject but thought I'd pose the question here as well. A lot of what I found only tells me how to determine tongue weight....don't need that. I'm probably going to use a ready made underbody tool box rather than fabricate one myself. I found some on Ebay 30"L x 10"H x 13"W which should be more than adequate for my needs and keeps the length of the overall unit shorter as well. So, has anyone ever run across a guideline for tongue length, if so....care to share?
I did read one place the tongue should be as long as 1/2 the width of the tow vehicle plus 8-12" extra. Seems like that would make for a rather short tongue if you consider 1/2 the width of a Tourer plus maybe 12".
ridingron
Orlando
Re: Need advice on trailer tongue length.
April 22, 2019, 09:08:22 PM »
My UniGo is 48" from axle center to the hitch pivot. If I had a choice, I would have it a little longer. Maybe 4"-6". I have never tried backing it up. I have towed other trailers with my truck and cars.
promo video:
https://www.youtube.com/watch?v=7YKqwU10BPk
Last Edit: April 23, 2019, 08:10:28 AM by ridingron
<a href="
https://m.maploco.com/visited-states/mine.php?states=AL-AR-AZ-CA-DE-FL-GA-KS-KY-LA-MD-MO-MS-NC-NM-NV-OK-PA-SC-TN-TX-UT-VA-WV
April 23, 2019, 03:42:44 AM »
Ron, I would have preferred to find a used Uni-go, much too expensive new. Found one in Wisconsin for $1k but bad timing on the money tree at the time. I'd like to get one of their hitches however.
ridingron
Orlando
April 23, 2019, 08:24:15 AM »
I didn't know if you had ever seen one. They are rather short, hence the 48" dimension. The link was to visualize the size.
I can't help with the hitch.
<a href="
April 23, 2019, 05:01:08 PM »
Yes, seen them in person, neat little things but the price is a bit above their worth.
mrtlc
Elroy WI
April 24, 2019, 03:35:52 PM »
Hey John Let me check tomorrow . There was one locally, way cheaper than $1000. I'll see if its still available. Terry
99 Interstate 1500
89 Goldwing sidecar 1500
88 Goldwing 1500
85 Goldwing 1200
84 Gold wing 1200
80 Goldwing 1100
79 Yamaha XT500
78 Honda 750K
Reply #6 on:
April 24, 2019, 07:13:14 PM »
My daughter lives in DePere, husband has his own business but they have a 40' camper parked on the water north of you I believe. Don't know how I'd get it here but might be worth it, they might be able to help me out. Send me an email on the trailer at:
stuffy402@gmail.com
=> InZane XXV
