December 31, 2025, 04:40:01 PM *
Author Topic: Db501 vs db522  (Read 1041 times)
NighthawkVTX
Gainesville, Fl
« on: April 29, 2019, 10:16:28 AM »
I was all set to purchase a set of db 501s as a direct swap out for my front speakers on my IS.
Then I heard the 522s are the replacement for the 501s.
I noted that the 522s are 5 1/2" speakers vs the 501 being a 5" speaker. Has any one put the 522s in the front of an IS? If so, how much " modifying" did it take?
If at first you don't succeed, then perhaps skydiving isn't for you
SCain
Rio Rancho, NM
« Reply #1 on: April 29, 2019, 10:31:52 AM »
I just purchased two sets of the db501's off of Amazon, thay are available, $60 a set.
And to answer your question, the 522's are too big, others will chime in.
Steve
NighthawkVTX
Gainesville, Fl
« Reply #2 on: April 29, 2019, 10:38:21 AM »
Cool how is the sound?
« Reply #3 on: April 29, 2019, 11:37:34 AM »
I put the bigger ones in my wing.  Took some carefull fitting and cutting but I got them in there.  BIG improvement in sound.
SCain
Rio Rancho, NM
« Reply #4 on: April 30, 2019, 05:05:19 AM »
Haven't installed them, so I don't know how they sound, should be an improvement over stock.
Steve
Paladin528
« Reply #5 on: April 30, 2019, 06:52:37 AM »
I have the 501s as well.  Not sure on the fitment of the 522
Paladin528
« Reply #6 on: April 30, 2019, 06:58:00 AM »
The DB522 is a 5.25 inch speaker so only 1/4 inch difference.  My bet would be on minimal modification since the holes needed to be elongated on the 501 to make them fit.
