December 31, 2025, 04:39:59 PM
Stupid question of the month
Topic: Stupid question of the month (Read 1071 times)
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
May 01, 2019, 07:23:44 PM »
Ok, somehow I will get grief for this but here goes, why is there a fuel and air rail? Why not a split and hose to each?
Pete
Re: Stupid question of the month
May 02, 2019, 04:39:53 AM »
Ease of original assembly on a production line??
rug_burn
Brea, CA
May 02, 2019, 07:35:59 AM »
Well, you gotta feed all the carbs, and they need to be stacked like they are in order to be right above each cylinder, which lends itself to the fuel rail setup.
Yes, the designer could have run hoses to each carb individually. But, this would add to the profusion of hoses already existing in the carb area: the 6 drain lines, the 6 vapor recovery lines, those 2 big hoses going to the air injection smog deal, and the several odd vacuum hose takeoffs and vent lines.
And fuel hoses are one of those things you really want to get right since if they leak, you could have a real disaster... So the engineers went with the heavier duty rail setup, it seems.
...insert hip saying here..
=> InZane XXV
