Adirondack Bill
« on: May 07, 2019, 02:20:50 PM » |
Like many of you, I am trying to move my handlebars back just an inch or two. I Don't want to mess with changes to any cables. I did a search on past threads, and it was mentioned that some people were able to use the 2 inch Rox Pivot Risers without having to get longer cables. Will these risers work on our bikes?? Isn't our speedo/tac in the way?? This unit does cover our handlebar mounts. I am not trying to move the bars up, just back about an inch. Any advice would be appreciated!
Kidd
« Reply #1 on: May 07, 2019, 05:29:07 PM » |
They worked on mine , I think mine are 2 inch . Mine lifted up some , the bars , made a lot more wind turbulence
Adirondack Bill
« Reply #2 on: May 08, 2019, 08:12:00 AM » |
Kidd- were you able to get your speedo/tac instrument unit back on over the new Risers without a problem or did you have to get longer mounting bolts for the instrument unit?
Kidd
« Reply #3 on: May 08, 2019, 09:48:05 PM » |
I did not do the work , there's a bike mechanic that lives .5 mile from me , works at home , I was happy to pay him . Sorry I can not help
Adirondack Bill
« Reply #4 on: May 09, 2019, 08:19:23 AM » |
Anyone else have Rox 2 inch Risers? I took the Speedo off to look at the bar clamps. The Speedo bracket mounts to the bottom set of bar clamps under the handlebars, and there is very little room between the Speedo unit and the top bar clamps. It just doesn't seem to be enough room to install higher risers in there. Why the hell Honda have to position the Speedo unit right on top of the handlebar clamps?? It is like they did not want anyone trying to modify this bike!
PAVALKER
Pittsburgh, Pa
« Reply #5 on: May 12, 2019, 01:02:27 PM » |
I have the 2in Risers and they worked well for up and back. The Speedo unit did not mount back on (with screws). I used Zip Ties to hold it down, but kept it a little loose as it sits on the top fine. You can get an bent piece of steel to connect the Speedo head, but you need to find someone to make one (and someone did at one point) but it's not necessary.
John
Adirondack Bill
« Reply #6 on: May 16, 2019, 03:56:19 PM » |
Thanks PAVALKER. I knew there would be issues getting the Speedo unit back on. I Don't know any metal fabricators who could do this. Do your Zip-ties show?
PAVALKER
Pittsburgh, Pa
« Reply #7 on: May 16, 2019, 08:32:43 PM » |
No.... not unless you knew they were there and where to look. They go thru the screw holes on the Dash panel underneath and then down to the original holes.
John
« Reply #8 on: May 17, 2019, 02:23:09 AM » |
I don't even have the original risers on my bike... it doesn't take much to hold that lightweight plastic speedo onto the bike, it is hooked on pretty solidly just by the gnarly wire harness... on my bike, where it was held onto the OEM risers, now it is held in place with these:  -Mike "fomotion clock holders"
enroute1
« Reply #9 on: May 17, 2019, 07:55:42 AM » |
I installed the 2" Rox and then the 3 " Rox Risers. Be advised that with the 3" risers no new longer cables are needed. What is required is that you unhook the wires and cables from the top clip on the handle bars allowing for more slack to accommodate the 3" risers. The zip ties work very well in holding the speedo unit.
« Last Edit: May 17, 2019, 07:57:42 AM by enroute1 »
2014 F6C Bordeaux Red Metallic
Adirondack Bill
« Reply #10 on: May 17, 2019, 08:47:17 AM » |
Thanks for the info guys. I am going to go with the 2 inch Rox risers.
Adirondack Bill
« Reply #11 on: May 22, 2019, 08:20:40 AM » |
Just a follow up: I installed the Rox 2 inch pivoting risers today. What a difference pulling the bars up a little and back an inch or so makes. Much more comfortable riding position makes. Install was fairly easy, except it was a little difficult to get to the bottom bolts to snug them up. Zip ties worked great to re-attach Speedo. Thanks guys!
PAVALKER
Pittsburgh, Pa
« Reply #12 on: May 23, 2019, 02:57:19 PM » |
Welcome....enjoy the ride.
John
tazzzed
« Reply #13 on: February 21, 2021, 07:02:51 AM » |
I know this is a bit dated, But has anyone come up with a better work around for putting the speedo back on? and for those that used zip ties have they held up? hate to be out in the sticks and have that thing bouncing around.........Thanks
Adirondack Bill
« Reply #14 on: March 01, 2021, 03:30:46 PM » |
When I first used the zip ties, I did not tighten them enough so the speedo went a little rooster-eyed. It did not "jump" around though. Each year I cut off the old ones and put new ones on- as tight as I can get them- no problems.
Farther
« Reply #15 on: March 01, 2021, 09:15:58 PM » |
Harbor Freight has stainless steel zip ties. I purchased some but have yet to use them so I can't vouch for their durability. But they may work better for you than the plastic ones.
Thanks, ~Farther
