December 31, 2025, 02:39:45 PM *
Pages: 1 [2]   Go Down
Author Topic: Tourer lights on but no start "update"  (Read 3808 times)
Earl43P
Farmington, PA
« Reply #40 on: May 23, 2019, 02:22:11 AM »
You HAVE a RH control but will continue to troubleshoot?  uglystupid2
Just CONNECT it, you don't have to INSTALL it until you know that fixes it.
08 Goldwing
21 KTM390A
99 Valkyrie IS Sold 5/5/23
VRCC #35672
VRCCDS # 0264
When all else fails, RTFM.
larue
Clermont,FL
« Reply #41 on: May 23, 2019, 04:44:55 AM »
That's right sir cuz I think I just found the culprit, I pushed on the starter solenoid red top plug and wiggle it bike fired up, turns out the wire were loose at the connectors, I ordered a new plug and will update you guys with results. Thank you guys for all the help
Earl43P
Farmington, PA
« Reply #42 on: May 23, 2019, 05:23:04 AM »
Great news cooldude
08 Goldwing
21 KTM390A
VRCC #35672
VRCCDS # 0264
« Reply #43 on: May 23, 2019, 05:31:50 PM »
Jump the relay?
I forget how-to, but I would think ignition on, and force the starter to turn. I don't want to suggest how I would do it, since I don't know, but it has been mentioned before.
You've done all that should have been done first.
« Reply #44 on: May 23, 2019, 06:28:08 PM »
pancho
Bonanza Arkansas
« Reply #45 on: May 24, 2019, 12:36:56 PM »
Hey larue, just for your info, there are actually two hot spade lugs on the relay, but only one female spade in the connector that carries ALL the power, except for the starter motor, to the bike. That single female spade has been a problem for many as it develops higher resistance over time making heat. A long term fix to lessen the chance of it ever coming up again is to put another female spade of the correct size into the blank space in the connector and wiring it parallel into the red power wire. This will provide an alternate parallel path for current flow to the bike and cut down on heating of the connections. Look at the wiring diagram, it shows two hot terminals on the relay, and I verified it to be true. I did a post with pictures about this fix awhile back, if interested, you could find it with a search.
« Last Edit: May 24, 2019, 12:46:04 PM by pancho » Logged
larue
Clermont,FL
« Reply #46 on: May 24, 2019, 04:51:02 PM »
 I think I just found the culprit, I pushed on the starter solenoid red top plug and wiggle it bike fired up, turns out the wires were loose at the connectors, I ordered a new plug and will update you guys with results. Got the part today reconnect the wires and the bike is back to life. Thank you guys for all the help.
Report to moderator     166.137.248.98
« Reply #47 on: May 24, 2019, 05:59:45 PM »
That's great to hear larue.  cooldude I'm still not clear of the issue. Was it just the wire plug in on the top of the relay wore and loose ?
larue
Clermont,FL
« Reply #48 on: May 24, 2019, 08:44:00 PM »
The wire connectors on the top red plug of the starter solenoid were loose and separating, when i pushed on it and started the bike it fired right up, so i bought one on amazyfor 5.99 came with four wires attached to it, I cut the old connectors off reconnected them to the wires on the new red top plug of the starter solenoid and bike fired up right away, problem solved
Paladin528
« Reply #49 on: May 30, 2019, 07:56:47 AM »
I use that spare for accessory power through a switched relay.
Pages: 1 [2]   Go Up
