December 16, 2025, 04:21:54 PM *
Author Topic: To all of you gurus "update "  (Read 1845 times)
larue
Clermont,FL
« on: May 15, 2019, 05:44:33 PM »
http://www.valkyrieforum.com/bbs/index.php/topic,106610.0.html#lastPost
« Last Edit: May 23, 2019, 04:50:27 AM by larue » Logged
Thunderbolt
Worthington Springs FL.
« Reply #1 on: May 16, 2019, 01:59:49 AM »
RP's link to the schematic's is not working any longer so couldn't reference that source but sounds like your starter switch is the latest problem.  First was when your battery went all the way down.  Any time your battery is "killed" by leaving something "on" it will never be the same.  Fix the starter switch first so that your headlights work when the ignition is on.  Buy a new battery after that.  Do you have a 12V test light?  Very handy for tracing 12V and ground problems.
I know you have another Valkyrie to compare with so use another one for reference.  If memory serves me correctly any time you short across the large connections on the solenoid the starter will turn.  Be sure the bike is in neutral before you do this.  All that the starter switch does is operate the solenoid and places that same short that you are putting across the two terminals.  Any starter that I have ever had to deal with could be tested out of the vehicle by using jumper cables.  Black to the case and Red to the 12V large terminal.  Once you put the red to that terminal the starter will turn.  You might have an open in the ground side of the circuit if your battery is known good and it will not turn when you short the terminals.  I think you compounded your problem after the battery died by damaging the starter switch..................
Good luck.  Keep this up Larue and you will be the Guru.  cooldude
« Last Edit: May 16, 2019, 02:15:02 AM by Thunderbolt » Logged
Steel cowboy
Spring Hill, Fl.
« Reply #2 on: May 16, 2019, 02:47:30 AM »
Bank angle sensor fallen over ?
2001 black interstate
2003 Jupiter Orange wing
indybobm
Franklin, Indiana VRCC # 5258
« Reply #3 on: May 19, 2019, 05:46:13 PM »
Another link to RP's schematics.
https://web.archive.org/web/20160401170712/http://www.rattlebars.com/valkfaq/schematics/index.html
So many roads, so little time
VRCC # 5258
Thunderbolt
« Reply #4 on: May 20, 2019, 02:07:01 AM »
Thanks for the link.  I have used RP's schematics many times.  Took a lot of work to make those.
Terry
Thunderbolt
larue
Clermont,FL
« Reply #5 on: May 22, 2019, 08:05:08 PM »
Opened the starter switch again, cleaned the contact over again, now my headlights are back on at least. Put new starter solenoid, took a battery out of my other Valk, no start on neutral, no start with kickstand up and clutch in in gear, even car jumped but zip nada no spurn over still, I have a used right hand control not ready to use till further troubleshooting  Sad
larue
Clermont,FL
« Reply #6 on: May 23, 2019, 04:49:47 AM »
 I think I just found the culprit, I pushed on the starter solenoid red top plug and wiggle it bike fired up, turns out the wires were loose at the connectors, I ordered a new plug and will update you guys with results. Thank you guys for all the help
pocket aces
Tampa, Fl
« Reply #7 on: May 23, 2019, 09:43:45 AM »
Sounds like you might have found your Gremlin.
larue
Clermont,FL
« Reply #8 on: May 24, 2019, 04:18:35 PM »
Connected the starter solenoid top cap wires back to the existing ones ,  plugged it back and bike is back to life  . Thanks everyone
Thunderbolt
« Reply #9 on: May 25, 2019, 02:57:09 AM »
Now you are the Guru Larue.  Glad you found it.  cooldude
