December 31, 2025, 02:39:50 PM
Db501 swap out
Topic: Db501 swap out (Read 1054 times)
NighthawkVTX
Gainesville, Fl
Db501 swap out
May 22, 2019, 09:06:56 AM »
I know I'm not the brightest bulb in the box, but I just don't see how the db 501 speakers are a direct swap out for the front stock speakers for the IS.
The hole alignment isn't even close.
Does anyone have pictures or thoughts on how to mount these things?
If at first you don't succeed, then perhaps skydiving isn't for you
Paladin528
Re: Db501 swap out
May 22, 2019, 10:16:11 AM »
you need to cut the outer ring off of the old speakers and overlay it on the DB501 to act kind of like a clamp. I used sealant on it to make the joint airtight.
There is a write up on here somewhere with pictures
pocket aces
Tampa, Fl
Re: Db501 swap out
May 22, 2019, 10:31:38 AM »
Front
https://s161.photobucket.com/user/wixthedog/library/Front%20Speaker%20Upgrade?sort=4&page=1
Rear
https://s161.photobucket.com/user/wixthedog/library/Rear%20Speaker%20Upgrade?sort=4&page=1
Paladin528
Re: Db501 swap out
May 23, 2019, 10:25:17 AM »
yeah thats the one
=> InZane XXV
