July 27, 2025, 06:25:10 AM *
Author Topic: installing back wheel on Honda Valkyrie 1500  (Read 1032 times)
barryroach0220
« on: May 28, 2019, 06:00:01 PM »
Hi everyone,
My first post in the forum.  I need someones help.  I replaced the back tire and replaced the 2 o-rings in the flange and the one in the final drive.  I've changed the back tire many times but this time I couldn't get the wheel to seat properly in the final drive.  I finally got the wheel on.  My question.  If the wheel is on with the spacer and brake caliper, does that mean the wheel is on correctly.  I'm trying to attach a picture.  The black cover on the final drive doesn't look right.  Can anyone help me with this?
Sorry, couldn't figure out how to attach a picture but I can send a picture via email or text.  Thanks, BR
« Reply #1 on: May 28, 2019, 06:17:19 PM »
Let me guess. There is a line/ small groove that you don't remember seeing and now that you are looking at it you think it should be closer to the dust cover.
It's fine. I hope you torqued the axel nut with the four final drive bolts loose and then immediatly torqued those four bolts.
If you did you should be golden
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: May 28, 2019, 06:23:57 PM »
...AND installed the thrust washer.
« Reply #3 on: May 29, 2019, 03:45:46 AM »
If we knew where you were, there might be a local rider close that could take a look advise you.
Rams.  crazy2
barryroach0220
« Reply #4 on: May 29, 2019, 08:25:03 PM »
ChrisJ:  You are absolutely right.  I see the groove and it doesn't look like the wheel is fully seated in the final drive.  If you say it's good, I'm going to finish putting it back together.  I torqued the axle nut and torqued the 4 bolts on the final drive.  the thrust washer is the plastic washer right?  I installed everything that I took off.   Thanks for your confirmation.
barryroach0220
« Reply #5 on: May 29, 2019, 08:27:07 PM »
I live in the metro Atlanta, Georgia area.
Lawrenceville, GA to be exact
« Reply #6 on: May 30, 2019, 03:42:24 AM »
Ya you are not the first to be bothered by that line. Sometimes when placing the wheel back into the drive you don’t get that “ I’m there” feeling. But if the wheel stayed in place good enough to get the axel through it was there. And like you said if all the metal is in and the axel is tightened down it’s all good cooldude
« Reply #7 on: May 30, 2019, 04:42:30 AM »
You could add that to your profile if you wanted to.
Alberta Patriot
« Reply #8 on: May 30, 2019, 05:26:50 AM »
And...if you didn't, you could not get the brake caliper bracket back into place.
« Reply #9 on: May 30, 2019, 05:41:24 AM »
« Reply #10 on: May 30, 2019, 10:02:29 AM »
I'd bet there is/are some knowledgable Valkyrie riders near you who would be happy to assist/advise you on this and folks you'll enjoy riding with.   I feel certain you will be glad you made their acquaintance.
Pluggy
Vass, NC
« Reply #11 on: May 30, 2019, 02:00:47 PM »
Hello Barry.  You may know this already.  The rear axle can be inserted through the rear wheel to support it as you line up the splines.  Makes it easy to mate them up.  Once the wheel is pressed fully into the driving splines, the axle comes out and you can put the rest of the parts together.
barryroach0220
« Reply #12 on: May 30, 2019, 06:10:32 PM »
Thanks for the tip about the axle and thank you for making confident that I have the wheel on right.  I love this forum. In addition to changing the tires,  I replaced the seals in the brake calipers because I suspected them of not operating properly because the brake pads wore out at each tire change and I use the brakes sparingly.  The wheel is on.  I'll just need to bleed the brakes now.  So if anyone has any tips or potential problems I may encounter I will appreciate them.
« Reply #13 on: May 30, 2019, 08:34:51 PM »
    Yer in the right place for ALL things Valkyrie. The knowledge here the willingness too help Never ceases to amaze me and I've been here a day or three. I've seen Valkyrie's torn down and repaired at Inzanes with parts carried by the members and the guy or gal that owns the Valk being repaired don't get to do much.  Roll Eyes I'd venture to say ANY problem you'll have has already been encountered and sorted out. There IS a wealth of knowledge stored on this site and Search Is your friend. Most of us that have a problem will post the problem and the eventual fix when problem is fixed. My I/S is a bit over 20 years old and Will put yer butt and back hard against the back rest when you twist her tail. Long as I own her or she owns me this board will help me keep her going and when I Finally have to give her up the next care taker can learn how here.  cooldude RIDE SAFE.
« Reply #14 on: May 31, 2019, 03:56:00 AM »
I changed seals on front calipers on a friends bike. No way to get any pressure to bleed until we filled the lines backwards with a syringe at the bleeders. Then all went normally.
barryroach0220
« Reply #15 on: May 31, 2019, 04:09:40 AM »
A syringe.  Cool, I would never have thought to do that.  I watched youtube videos on a guy bleeding the brakes.  It appeared that he was having trouble getting it done.  Thanks for the great tip.
« Reply #16 on: May 31, 2019, 04:32:35 AM »
I bought a pneumatic brake bleeder from Harbor Freight it makes bleeding the brakes and clutch much easier to do.
https://www.harborfreight.com/brake-fluid-bleeder-92924.html
baird4444
« Reply #17 on: June 03, 2019, 04:39:53 PM »
I use this one-  https://www.harborfreight.com/brake-bleeder-and-vacuum-pump-kit-63391.html?_br_psugg_q=brake+bleeder
and it works great.I just need a second person to keep the reservoir topped off. great way tochange out fluids.
         - Mike
    - ya gotta be SOBER!
     -Cody Baird
da prez
Wilmot Wi
« Reply #18 on: June 05, 2019, 08:14:32 PM »
  The syringe method is a version of reverse bleeding.  Remove the furthest caliper. Remove the pads. Put in a piece of 1/4 plywood or worn out brake pad. Pump the brakes until the pistons come out against the spacer.  Open the bleeder and work like you are bleeding the brakes with the bleeder to the top. When fluid starts coming out , shut the bleeder and have the brake hose to the top and hose as straight as possible. Push the pistons back in all the way. They should now be bleed. Repeat on other calipers.
                                        da prez
