December 31, 2025, 12:57:42 PM *
Author Topic: Avon Cobra Chrome PSI ?  (Read 1229 times)
mikeirion
Frankenmuth, MI
« on: May 31, 2019, 01:02:58 PM »
Just went for a long ride on my totally refurbed Interstate. Had an ankle replaced two years ago February and the bikes have been neglected until now. New tires, new windshield, new brake pads, new fork seals and oil, changed all brake and clutch fluids, motor oil and filter change, new rear spline and oil and rear end maintenance. I put on the Avon Cobra Chromes and they feel great, but new tires always feel like you can scrape pegs again. I put 33 psi in both but wondering what others are running at. Now for a carb sync and valve adjust, last one was at 10,000 and now there is 40,000 on the clock.
2000 Interstate
1997 Standard Modified
Challenger
« Reply #1 on: May 31, 2019, 01:54:42 PM »
I run 41 front and 40 rear, some run higher. I don't think your tires will last long or give you good service at 33 psi. My Avons scalloped badly at 36 psi like the manual states.
RWhitehouse
« Reply #2 on: May 31, 2019, 02:33:54 PM »
I've always had best results keeping the front at 40. The manual says 36, but my experience echoes everyone else and that lower PSI tends to result in the tire cupping/wearing weird.
Currently have about 7000 on a Dunflop 404, always run at 40, and it's actually wearing excellent so far.
« Reply #3 on: May 31, 2019, 02:35:08 PM »
33psi is too low unless you enjoy cupping and tires wearing out in less than 10,000 miles. 40ish front and back is more like it. I do 40 in the front and 42 rear. I get over 20 thousand miles on tires always
« Reply #4 on: May 31, 2019, 02:50:03 PM »
40-42psi.
Remember that car/cage manuals are not only written by engineers.  Salesmen (and lawyers) get input too.  It's my lifetime experience that recommended psi's for tires are lower than optimal for tire wear, and even optimal handling/braking.  People like a smooth ride, and soft tires give them one.  Manual writers could give a rat's ass if your tires wear out in no time.
Also, manuals are only written for OEM tires, not every tire you may ever replace them with.
I don't know about today, but for decades OEM tires on new vehicles were always mediocre at best (to hold down overall cost).
Paladin528
« Reply #5 on: June 03, 2019, 04:39:37 AM »
from Avon themselves...
All other Touring/Cruiser Models
                     Solo        2 up light     2 up heavy
Front           38-40          40-42           42
Rear            38-40          40-42           42
RWhitehouse
« Reply #6 on: June 03, 2019, 07:24:25 AM »
40-42psi.
It sometimes goes the other way also. I owned a Indian Scout, a small, sporty cruiser. The manual asked for 40/42 psi, in it's OEM craptastic Kenda tires. Those tires, at that pressure were greased wooden hoops. The rear was comically easy to spin up and the ride was rock hard.  No bueno. I found running the tires at 30/32 was a huge improvement to grip and ride quality. Most owners agreed, Indian in general seems to recommend near or at the max PSI for the tires, I guess to try and extend tread life or fuel economy, who knows. Suzuki did the same thing, even on it's sportbikes the manual called for high pressures for really no reason. A GSXR apparently needs 42psi, where a CBR, ZX, or R6 only needs 32. For the exact same tires, same wheels, similar weight and power.
