February 04, 2026, 12:47:12 PM *
Author Topic: Americade day run if anyones want to join in.  (Read 1760 times)
Dan-bury
Danbury CT
« on: June 04, 2019, 10:27:47 AM »
A few of us are riding up Thursday for the day if anyone wants to sneek away and ride.
I have spent most my money on Motorcycles and Women, the rest I just wasted.
Karen
Boston MA
« Reply #1 on: June 04, 2019, 05:09:34 PM »
What time and from where?
Karen
Boston MA
« Reply #2 on: June 04, 2019, 11:33:31 PM »
Never mind... makes more sense to ride directly from here... Keep an eye out for Shorty and Dianne, they're coming up from TN...
dalai-lama
Wish I was out riding...
Watertown CT
« Reply #3 on: June 05, 2019, 02:27:13 AM »
No possibility for me.  Enjoy the ride.
Karen I have not forgot you.  Ran into some issues and got behind.  Do have a trailer lined up for when i need it however.
the dalai
Karen
Boston MA
« Reply #4 on: June 05, 2019, 06:05:28 AM »
Brett, no problem! Shorty had suggested that I just rent a UHaul and bike trailer to get it over there, and save you a wasted day... makes perfect sense to me. Finally got the air filter cleaned and lubed and back in place. Ordered the OEM gas lines, and will attempt to get it back to stock and see if it runs. Decided against Americade this year, weather looks so so... On a positive note, the scooter has gone to its new home, and Matt sent me a picture of it all stripped down, it passed the compression and leakdown and another test, and he even chased the electricals to find the original LoJack, and asked if that was what it was. Definitely has gone to a good home, and I hope he and his family enjoy it as much as I did. Still getting used to the NM4, but we did a ride through Myles Standish State Forest last weekend, and I was very pleased with the handling and response. No apoligies accepted, Brett, you can say "I told you so" for eternity... 2funny
Dan-bury
Danbury CT
« Reply #5 on: June 05, 2019, 09:00:46 AM »
We'll be leaving Danbury area around 7:30 and should get up there and start wandering the vendors by noon.
I'll keep an eye out for ya all.
Sorry to hear Brett, hope to see you some day soon!!!
GaryC
Uxbridge, MA
« Reply #6 on: June 05, 2019, 02:18:21 PM »
it's been raining on and off since Sunday, no really heavy rains just an annoyance. Predicting Thursday noon through the rest of the week and weekend to be nice.  Although it's only Wednesday (evening) this is the quietest I have ever seen it here. There are vacant signs at just about every hotel/motel including the prime locations.  Roads are in great shape with a good portion off 9N with new pavement. The thin crowds make for good riding.
Hope to spot some of you tomorrow.
Enjoy.
« Reply #7 on: June 06, 2019, 01:15:54 PM »
I see its open Saturday
Leaving at 6am should be there by 930  visit both vendor areas and maybe get a new helmet and earphones and mic and some knick knacks for the bike
« Last Edit: June 07, 2019, 03:56:17 PM by Oss » Logged
dalai-lama
Watertown CT
« Reply #8 on: June 09, 2019, 05:18:05 PM »
Sorry guys and gals, I am trying to make a concerted effort to check in.  I thought I was going to be slowing down but no such luck.
Karen, it is not the trailer that is the issue it is that I have no where to put the trike just yet.  I have been battling a coolant leak on the Valk. I changed the thermostat as I was getting intermittent high temperatures so I figured after 20 years, it was probably due to be change.  That was my first mistake.
Since then I have had a small coolant leak.  Figured that when I changed the thermostat I disturbed the coolant pipes from the thermostat to the heads.  Those o-rings are 20 years old and through thousands of heating/cooling cycles.  So I pulled the heads and changed the o-rings.  It was easier to pull the heads than pull the airbox and carbs.  The second mistake.
I put the heads on and fired up the bike and something was amis.  A compression check showed no compression in the #1 cylinder.  Off came the right head and I found the the boy's help that the intake value was not quite seating.  It seems that when I put the head in, I did not back out the valve adjust quite enough and when I turned the cam to lign up the cam with the crank, I must have bent the valve stem.
So looking at parts which doing all the valves over (no sense in doing just one) was at about $750 I decide to just get a used head from pinwall.  Installed the head and all good.  Until the coolant leak showed up again.
So I broke down and pulled the airbox and the carbs and the deflector over the the thermostat.  And pressurized the system an see a leak from the thermostat.  Checked that and finally found that the thermostat came with a bad gasket.  Pulled one from the other bike that is in a million pieces in the garage (another boy story) and put that in.  No leak from the thermostat but now a leak from the coolant pipes into the thermostat.  So I had ordered the orings for that and they were in stock in the shelves, to I changd those.  Pressurized the system and no coolant leak.  Finally!
Then life gets in the way and it is taking me a while to get the carbs all back in.  Today the cable for the audiovox cruise control breaks.  They don't make that anymore so I am trying to get a custom cable made.
Yesterday the boy and I went to Kentucky (La Grange) to pick up a frame for a race buggy that he wants to build.  25 hours road trip.  He was using my truck and I wanted it to be not in a mangled condition so I went along to make sure that there was no sleeping and driving going on.
So all of these things have gotten me behind in getting $hit cleaned up in the garage so that I can get the trike in.  I have a brand new 56" tool box that I moving all of the tools to and need to just do that an throw some $hit out.
Working at iDevices has been interesting.  A few months ago the project I was working on was cancelled.  So all of a sudden there was about 25 engineers with nothing to do.  It was the right decision to cancel the projet as though technically it would work, it was way over budget.  And a year and a half in development when it should have taken about 6 months.
So I was in a bit of depression I think as I had left my old job and now I had nothing to do in my new job.  But i have found my way here and found my voice and my leadership and my "frankly I don't give a $hit attitude on speaking my mind" again when I see $hit being done wrong.
So work is okay again.  The lunches and the beer were always great.  But I am putting in quite a few hours again and have 2 hours a day travle.
I am also working for my old company as a consultant as they are lost.  Seriously lost.   So 15 to 20 hours a week I am doing work for them.  But that does not leave much time when I leave for my day job at about 6:30-6:45 and get home 6:30-7:00 and then work for another 3-4 hours with my old job.
So that is where I have been.  Don't see it letting up until sometime in July.  Although I have unlimited vacation, I have to put in a week in advance for a day off, a month in advance for a week off, and 3 months in advance for more than one week of in a row.  Not that there is a policy and procedure manual that they point at to let new employees know.
I have been listening to some country music and after a few coctails, this song comes on
https://www.youtube.com/watch?v=lB8Nkn3Xjes
and I am pretty close to just doing that.  Putting my toes in the water and my $ss in the sand.
So just for the disclaimer, this it the first real "mistake" I made with the Valk over the years.   Costing me a bunch of time that I don't have.
So once i have the tools moved over to the new box and throw a bunch of $hit away, I will have room for the trike.  That is really what is holding me up. The work on it will be less than a weekend to get everything done correctly.  My neighbor just bought a nice trailer and I told him "I'm borrowing that" so transportation is a non-issue.
So bear with me on this Smiley
the dalai
ybnorml
« Reply #9 on: June 10, 2019, 03:46:52 AM »
Damn Brett.....Doesn't seem as you have allowed yourself time to take a $hit !!!
Or must you put in 1 week in advance for that too ???
I admire your enthusiasm Brett, for taking on 'plenty of projects'.....but wholly f*^k dude,
ain't it about time to let go of some of that stress created by all those projects / working
for your old company ??
Tony C.
Massachusetts
« Reply #10 on: June 10, 2019, 05:31:43 AM »
Wow Brett! Terry essentially posted all the things I was thinking. At a minimum, I would cut ties with your former company. You don't owe them anything.
I hope you're going to be able to slow down a bit. This pace is not sustainable over the long haul. I wish you well my friend.
 Cool
Dan-bury
Danbury CT
« Reply #11 on: June 10, 2019, 12:51:00 PM »
Brett,, I will just pass along something my Father used to tell me...
Never get so busy making a living that you forget to make a life !!!!
Karen
Boston MA
« Reply #12 on: June 10, 2019, 02:09:34 PM »
Brett, I am not in a hurry! Loving the Vultus, Put a rack and top box, and storage is acceptable for now. Need to spend more slow speed maneuvering time, will do! Bought the OEM gas lines for the valk, and will replace the mess and see what happens. Please don't worry, what everyone else said, take some time for yourself, work will help pay for your retirement, but that's not what really matters... not in a rush!
holmes
« Reply #13 on: June 10, 2019, 03:01:52 PM »
Brett
Quit your crying and get it done   angel
dalai-lama
Watertown CT
« Reply #14 on: June 11, 2019, 04:47:48 PM »
Brett
Now that is what I expect to here  cooldude
the dalai
holmes
« Reply #15 on: June 11, 2019, 05:39:29 PM »
Brett
When you need a hand, I'm your huckleberry. You let me know
