valk2128
« on: November 27, 2009, 11:05:24 AM » |
I am planing on replacing the Fork Springs on my 1998 Valkyrie.
What do you all think, Progressive springs, or OEM??
« Reply #1 on: November 27, 2009, 11:19:51 AM » |
Don't even consider OEM - go progressive... unless you like pogo sticks  -Mike
Wildman
« Reply #2 on: November 27, 2009, 12:35:33 PM » |
If you like performance riding and can tolerate a slightly taller seat height you might consider the RaceTech springs and gold valves. A little more complicated install if you choose to go with the gold valves. I have the entire RaceTech setup with seals, slider bushings, Gold Valves, and springs. I like the set up a lot. This with long progressive 440's in the back with HD springs for me, get the valk up a little higher for better lean angles and state of the art handling for a Valk.
F-106
« Reply #3 on: November 27, 2009, 01:32:10 PM » |
I replaced my OEM springs with the progressives this summer. No more bottoming out since I change them. Big improvement. I had a fork seal go bad so it was a good time to change them since they had the forks torn down .
PAVALKER
Pittsburgh, Pa
« Reply #4 on: November 27, 2009, 03:28:31 PM » |
I did progressive springs and also replaced the fork seals, bushings and fluid. So far I love it....
John
Tri Dragon
2001 Valkyrie Interstate Trike
Campbell River, BC, Canada
« Reply #5 on: November 27, 2009, 09:40:09 PM » |
I put Hd Progressives in my 2001 IS along with seals and 20 wt oil. Much nicer ride, no bottoming out. Also put 61/2 deg raked tripple tree in.
Ride what you want and Ride it until you Rot!
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #6 on: November 29, 2009, 05:56:44 AM » |
Go Progressive and don't look back! I was really amazed when I switched, I did the rear shocks with progressive at the same time, so my overall change in performance/ride was probably more noticable. Rides better, handles better, brakes better ( no more nose diving when grabbing a handfull of front brake) Keep in mind, my rears were 10 years old and I had no idea how bad they were until removed. I could collapse and extend them easily by hand!
Puffs Daddy
« Reply #7 on: November 29, 2009, 06:54:39 AM » |
+1 on the RaceTech springs. (I don't have the entire RaceTech setup with gold valves.) On the back I have Works Performance shocks. The combination made a huge difference in the Valk's handling. P.S. I've noted on other threads that Works Performance now has an Ebay store where the price of selected shocks is closer to the less expensive Progressive units. Worth checking out.
rmrc51
Palmyra, Virginia
« Reply #8 on: November 30, 2009, 10:11:16 AM » |
Would you all also suggest Progressive springs up front for a Valkyrie Trike???
VRCC # 30041
frosty
« Reply #9 on: November 30, 2009, 07:33:18 PM » |
I had thought of going with Progressive also. HDL still has their sale on I think. Also probably will change out the seal, bushings and all too. That does add more to the cost of the project but probably the time to do it.
Ken Tarver
« Reply #10 on: November 30, 2009, 08:51:27 PM » |
rmrc51.....yes on the Progressives for your trike, most definately sir!
Ken
rmrc51
Palmyra, Virginia
« Reply #11 on: December 01, 2009, 03:15:38 AM » |
Ken
Thanks Ken!
VRCC # 30041
rmrc51
Palmyra, Virginia
« Reply #12 on: December 01, 2009, 03:17:13 AM » |
What is a good source to buy the Progressive springs?
VRCC # 30041
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #13 on: December 01, 2009, 03:51:34 AM » |
They've gone up in price like everything else. I think I paid about $60.00 for mine. Still worth the price http://www.directlineparts.com/product.asp?pid=554&str=2
rmrc51
Palmyra, Virginia
« Reply #14 on: December 01, 2009, 06:05:36 AM » |
Thanks Tundra!!! I'll be ordering these springs. If anyone has a source for the seals and replacement oil, please post!
VRCC # 30041
« Reply #15 on: December 01, 2009, 07:50:41 AM » |
Thanks Tundra!!! I'll be ordering these springs. If anyone has a source for the seals and replacement oil, please post!  Same place... start at www.directlineparts.com and you can drill down to whatever you need... OEM parts, or tires, or accessories, or ... -Mike
rmrc51
Palmyra, Virginia
« Reply #16 on: December 01, 2009, 08:12:12 AM » |
Gotcha Mike! Thanks.
VRCC # 30041
Jeff K
« Reply #17 on: December 03, 2009, 12:37:39 PM » |
+1 on the RaceTech springs. (I don't have the entire RaceTech setup with gold valves.) On the back I have Works Performance shocks. The combination made a huge difference in the Valk's handling. P.S. I've noted on other threads that Works Performance now has an Ebay store where the price of selected shocks is closer to the less expensive Progressive units. Worth checking out. Which racetech springs do you have? I have a set of .95s and they were way too soft. I took them back out.
