December 31, 2025, 11:07:29 AM
Headlight bucket indicator LED replacements
Topic: Headlight bucket indicator LED replacements (Read 1116 times)
Visseroth
June 16, 2019, 01:51:17 PM »
So over the winter I replaced the lights for the turn, neutral and high beam with LEDs and just noticed (as I haven't ridden much) that my turn signal seems to reverse polarity when switching from left to right.
So currently if I turn on my left turn signal my indicator light flashes, but if I turn on the right turn signal it doesn't flash.
So, my question is, how have others gotten around this?
Is there a dual polarized white or orange LED light that can be put in this or do I need to go back to halogens?
'98 Honda Valkyrie Standard 1520cc
Re: Headlight bucket indicator LED replacements
June 16, 2019, 05:34:33 PM »
The current goes in opposite directions through the indicator, thru the other turn signal to ground. The LED is a one-way valve as it were. I and others have detailed this several times. Use the advanced search function and look for "markt" with "LED indicator" you'll find the discussions and what you need to do.
Visseroth
June 16, 2019, 09:38:37 PM »
Oh, now you tell me
Well unfortunately I've missed that detail over the years so I went ahead and ordered some LEDs that are not polarity sensitive. We'll see how they work out when they come in...
https://www.superbrightleds.com/moreinfo/miniature-wedge-base/194-led-bulb-4-led-miniature-wedge-retrofit-car/198/863/
https://www.superbrightleds.com/moreinfo/miniature-wedge-base/194-led-bulb-1-led-miniature-wedge-retrofit-car/197/851/m
One looks like it has 4 diodes so it should route the electrons as needed.
Wayn-O
Orem, UT
June 17, 2019, 08:59:10 AM »
I've read that these work:
https://www.amazon.com/dp/B072MYWN7N/ref=cm_sw_r_cp_apa_6EzUBbNNWS9B2?fbclid=IwAR2QVdCZl_k-MNhFYVWYw4r1nHZO5LZpRWB2VXF0TIbA9JEeJWkANrTILmk
2000 GL1500C Valkyrie
2003 VT1100C Shadow Spirit
1998 VT1100C Shadow Spirit
1983 VF750C V45 Magna
Gondul
VRCC #408
Central Florida
July 24, 2019, 03:26:52 PM »
Quote from: Visseroth on June 16, 2019, 09:38:37 PM
Oh, now you tell me
Did the 194s fit in the headlight bucket?
I'm having a hell of time searching through trying to find the right size so I can finish ordering all the lights from SuperBrightLEDs
As the Government of the United States of America is not, in any sense, founded on the Christian religion....
John Adams - 1797
Because Thou lovest the Burning-ground,
I have made a Burning-ground of my heart
That Thou, Dark One, hunter of the Burning-ground,
Mayest dance Thy eternal dance.
=> InZane XXV
