March 28, 2026, 01:56:22 PM *
Author Topic: fuel tank  (Read 679 times)
barbones
« on: June 22, 2019, 09:08:46 AM »
what tanks will fit on a 2001 standard?
« Reply #1 on: June 22, 2019, 09:26:44 AM »
Any year, any model ‘97-03 will fit
« Reply #2 on: June 22, 2019, 10:08:12 AM »
Your seat might be a little snug with an Interstate tank, but it will fit.
Glaserbeam
Southern California
« Reply #3 on: June 22, 2019, 10:50:45 AM »
Definitely get the interstate tank (unless you have the velocity stacks on your carbs which might hit the sides of the tank).  You'll appreciate the extra 25% fuel range.  Bolts right on, as long as the extra port on the bottom is blocked with the stock fuel level pickup assembly or similar cover.
barbones
« Reply #4 on: June 24, 2019, 04:49:38 PM »
Thank you all. first waiting to see if body shop can fix mine after the deer attack. It an 8 gallon custom I would hate to loss it. Just needed to know my other options. Thanks again.
ridingron
Orlando
« Reply #5 on: June 24, 2019, 09:48:04 PM »
...  It an 8 gallon custom I would hate to loss it. ...
From who or where did you get the tank?
« Reply #6 on: June 29, 2019, 05:25:25 PM »
Pictures?
I had read that there was a large capacity aftermarket tank made for the Valk, but I would expect that it is pricey. Repairs being covered under insurance? Then get it replaced/fixed.
« Reply #7 on: June 29, 2019, 06:00:18 PM »
Pictures?
yrs ago, it was fiberglass and about 10 gallons. ethanol killed them.  I don't know of any others out there except for the few custom ones made by riders, usually they widened the OEM one
