November 14, 2025, 07:35:57 AM *
Author Topic: Quick Petcock Pingel 1311-CH question  (Read 1038 times)
ValkrieFromHell
Sacramento, CA
« on: June 26, 2019, 11:04:36 AM »
Hello, after reading some hundred petcock posts I have a quick question before I buy this petcock on Ebay. This one is a bit cheaper than pingels website so does this work everything adds up like 22mm but only problem is it says 22mm outlet not inlet is that a problem or no problem? Also has the same part number 1311-CH. Thanks for your time! Here is the link: https://www.ebay.com/itm/Pingel-1311-CH-Power-Flo-Gas-Valve-22MM-Outlet-Facing-Forward-Harley-Davidson-/183797854805?_trksid=p2349526.m4383.l4275.c1#viTabs_0
« Last Edit: June 26, 2019, 11:06:40 AM by ValkrieFromHell » Logged
« Reply #1 on: June 26, 2019, 11:13:36 AM »
It’s the outlet for the tank. That’s the right one cooldude
Ken aka Oil Burner
Mendon, MA
« Reply #2 on: June 26, 2019, 01:26:31 PM »
That's the right one, and the same seller I bought mine from on Ebay. No problems with the transaction at all.
