November 14, 2025, 07:34:34 AM
Final Drive Thrust Washer
Topic: Final Drive Thrust Washer (Read 1244 times)
Dragon4056
Waco, TX
June 27, 2019, 04:21:30 AM »
Does it wear? Should it be replaced along with o-rings each tire change?
Re: Final Drive Thrust Washer
June 27, 2019, 04:33:17 AM »
Quote from: Dragon4056 on June 27, 2019, 04:21:30 AM
I've replaced it before. It was hard to tell the difference between
the old one and the new one. If it looks OK, it probably is OK, should
last way longer than a tire...
June 27, 2019, 04:39:08 AM »
They get thin over time. They don’t need changing every time but every few years. I can tell just by holding a new one and old one when the old one is thin
Last Edit: June 27, 2019, 05:06:36 AM by Chrisj CMA
Dragon4056
Waco, TX
June 27, 2019, 04:48:43 AM »
Thanks guys, small price to pay. Will order a few.
June 27, 2019, 04:53:54 AM »
Just order one unless you're concerned they won't be available in the future. They last a long time. Remember to grease them before installing.
Steve K (IA)
Cedar Rapids, Iowa
June 29, 2019, 10:47:20 AM »
Quote from: sandy on June 27, 2019, 04:53:54 AM
States I Have Ridden In
Reply #6 on:
June 29, 2019, 12:51:12 PM »
Cut one out of a milk/water jug
Rio Wil
Reply #7 on:
June 29, 2019, 06:21:51 PM »
I cut one out of about .015 oil resistant gasket material.....and added it with the plastic one.......took some of the slop out of the flange piece........works fine Just don't over do it,,,,,when you torque down the axle nut, the wheel won't spin.....chuckle
=> InZane XXV
