December 31, 2025, 11:06:53 AM
Dipsticks
Topic: Dipsticks (Read 1113 times)
VALKen
Dipsticks
July 05, 2019, 02:21:23 AM »
I just noticed that the part numbers of the dipsticks for the Gold Wing and the Valkyrie are different. Anyone know what the difference is in the actual parts?
I would assume they will physically interchange, but do they represent a different oil level in the 2 bikes? Or is it simply a different upper (i.e. external) shape?
Re: Dipsticks
July 05, 2019, 02:50:57 AM »
As long as it reaches the oil it really doesn’t matter. Drain, fill with a fresh gallon and wherever the oil lands on the stick is where it needs to be. You can even make your own mark if you want.
Re: Dipsticks
July 05, 2019, 07:29:01 AM »
same engine short block, same oil capacity per both respective technical manuals.
Re: Dipsticks
July 05, 2019, 11:12:58 AM »
To be honest, I hardly ever even check the oil level anymore. I did for years, and it never changed. Now I just change the oil and filter, put in 4 quarts and forget about it.
Re: Dipsticks
July 05, 2019, 01:06:29 PM »
Quote from: meathead on July 05, 2019, 11:12:58 AM
Exactly, I do check the oil by looking at the floor under the bike. If there’s no oil then I know it’s all still inside
Re: Dipsticks
July 05, 2019, 02:44:27 PM »
Quote from: Chrisj CMA on July 05, 2019, 01:06:29 PM
Amen had my bee for 22 yrs and has never used a drop so I never check it
Gideon
Indianapolis, IN.
Re: Dipsticks
Reply #6 on:
July 05, 2019, 05:46:14 PM »
I do the same.
But they that wait upon the Lord shall renew their strength; they shall mount up with wings as eagles; they shall run and not be weary; they shall walk, and not faint. Isaiah 40:31
oldsmokey
Mendon Massachusetts
Re: Dipsticks
Reply #7 on:
July 06, 2019, 04:11:27 PM »
Could it be black vs chrome?
=> InZane XXV
