December 31, 2025, 11:06:47 AM *
Author Topic: Desmog/PAIR removal  (Read 916 times)
VALKen
« on: July 05, 2019, 05:19:16 AM »
I know that there are kits available, but where's the fun in that.  Wink
I'm thinking about how to make plugs that require no bracket on top to hold them in place. How much pressure do they need to withstand? I doubt there's much pressure trying to push a plug out. Even the Honda original parts use a simple bracket, but I like the idea of a plug with a central screw that you just tighten a bit to lock it in place - obviously with an O ring at the top. But how much pressure is there underneath the cap?
Sometimes it's negative, so sucking the cap on (that's how the PAIR system works), but when positive, how much positive.
Anyone any thoughts on this?
« Reply #1 on: July 05, 2019, 07:46:50 AM »
Well, If this helps, I just replaced a carb bank on a friends bike and upon close inspection to make sure all was done right I noticed the hold down for one of the airpipes was missing.  I found it stuck in a crack but it had been off its perch for a long time and the pipe fitting did not get pushed out.
VALKen
« Reply #2 on: July 05, 2019, 11:01:55 AM »
That's what I wanted to hear.  Grin
da prez
Wilmot Wi
« Reply #3 on: July 05, 2019, 03:50:00 PM »
14mm freeze plug.
             da prez
