December 31, 2025, 11:07:30 AM *
Author Topic: Belly Tank Fuel Pump  (Read 1102 times)
Dragon4056
Waco, TX
« on: July 06, 2019, 05:38:44 PM »
Mine still working fine. Would like to purchase one as a backup. I've emailed RM with no reply as of yet. Anyone know if it is a common pump? Where to purchase? Tag has come off mine, Brand? Part #?
Thanks for info.
ridingron
Orlando
« Reply #1 on: July 06, 2019, 06:48:25 PM »
I bought a package of 4 off ebay. A little more than a new one. Supposed to be new but not in a package.
Purolator Facet FAC 40178
« Reply #2 on: July 07, 2019, 03:26:45 PM »
So did I.  Looks identical and made by the same people as the OEM.  I installed the first and it's working as it should.
« Reply #3 on: July 08, 2019, 06:42:33 AM »
BTW you can improve the fuel pump install by replacing the brass elbow with a T and a plug.  Then you have a belly tank drain if needed.  Which will also drain the main tank.  Like this:
rhinor61
Northern California
« Reply #4 on: July 24, 2019, 12:25:49 PM »
Great idea about replacing with a T... Do you have to remove the bell tank to replace the fuel pump or any other hardware?
John M
John
Northern California
1998 Valkyrie Tourer Black/jade
VRCC #28001
