March 28, 2026, 10:19:40 AM *
Author Topic: Bought a new to me trailer  (Read 945 times)
Big Rick
2000 Valkyrie Interstate
Franklin....Ohio
« on: July 09, 2019, 04:56:22 PM »
to tow behind my Interstate, I am talking with Da Prez about getting a hitch for the bike.
 My question is this....is there a premade wiring harness to buy? or will I have to build a wire harness to fit with the flat four connector on the trailer?
 I am no electrician, so either way I will be having a friend wire it all up for me  uglystupid2
 thanks in advance for any info.....and sorry if this is posted in the wrong category '
   Big Rick
« Reply #1 on: July 09, 2019, 05:20:48 PM »
This is what I have been using for years with no problems. It's pretty easy to wire up. Although, I wouldn't use their crimp style connectors. Or any others. I just made up some bullet connectors.
https://www.amazon.com/Hopkins-46255-Power-Taillight-Converter/dp/B000CMKG6O
« Reply #2 on: July 09, 2019, 09:29:54 PM »
Mr. Head's unit is what I used on 2 bikes. Still have one of them. If your trailer is all LED's, this unit isn't the right one. Can't remember the Hopkins number for the LED version.
« Reply #3 on: July 10, 2019, 05:23:21 AM »
Add this circuit to the bike and it powers the trailer lights, LED or incandescent, using a 4-pin flat connector.  If you can follow a diagram and solder or have a friend do it, this is easy.  Bonus, you also get RBT on the rear marker pods (or any other rear signal lights) and you don't have to change the tail light fixtures - 1156 sockets work.  However you should change the bulbs to LED arrays as incandescent make too much heat and will melt the plastic parts inside the pods.  Autozone has them, I got mine from superbrightleds.com  I installed this circuit on Jade and Deerslayer.
« Last Edit: July 10, 2019, 05:39:02 AM by MarkT » Logged
« Reply #4 on: July 10, 2019, 05:51:37 AM »
just out of curiosity, how many relays do you have total on your 4 bikes ?
« Reply #5 on: July 10, 2019, 06:39:37 AM »
There's 22 (I think) on Jade.  A dozen or so on Deerslayer. I think 2 on George just for the headlight power upgrade.  No extras on Marty which is stored as a parts bike.  They very rarely fail, having bought quality relays, not Chinese junk.  Any failures are usually the connectors slipping off the pins.  I try to give them a squeeze so they have enough friction.
« Last Edit: July 10, 2019, 06:50:27 AM by MarkT » Logged
Ken aka Oil Burner
Mendon, MA
« Reply #6 on: July 10, 2019, 07:36:39 AM »
I used this from Shoptalk:  http://www.herberts.org/wayne/valk/trailerlights.htm
Big Rick
Franklin....Ohio
« Reply #7 on: July 10, 2019, 01:38:37 PM »
thank you for all the answers guys...I do appreciate them
Mr Whiskey
« Reply #8 on: July 13, 2019, 08:19:06 PM »
Call Lewis @... 865.219.9192
https://electricalconnection.com/index.php/product/isolator-honda-gl1500/
Pretty sure mine for the Interstate was plug-n-play cooldude
Great guy with quality products & customer service!
(not affiliated, jus' very satisfied customer... he jus' fixed all my Wing gremlins couple weeks ago!)
Peace, Whiskey.
