December 31, 2025, 11:07:23 AM *
Author Topic: Fork Leals  (Read 1231 times)
Jruby38
Oxford Mass.
« on: July 10, 2019, 05:17:51 PM »
I want to replace my leaking fork seals. I read Valknorway post about front fork dismantle but he dos not explain  how to reassemble with the stop ring?
« Reply #1 on: July 10, 2019, 05:59:59 PM »
There's a You tube video on rebuilding VTX 1800 forks. They are the same design internally. You would benefit from buying a factory service manual.
Tfrank59
'98 Tourer
Western Washington
« Reply #2 on: July 10, 2019, 07:15:38 PM »
You might want to read a couple of posts about cleaning leaky seals first.  I had a leaky right side fork seal, bought a Seal Mate (others prefer Seal Doctor) on the advice of forum members and voila, no more leaky!  That was over four years ago.
-Tom
dancnman
Houston, Texas
« Reply #3 on: July 11, 2019, 03:29:56 AM »
And, pay the extra money for Honda seals instead of All Balls. The All Balls just don't fit right. As mentioned, get a service manual and get to it. The special tools needed can be found on ebay for cheap.
Reality is that thing which does not change simply because I choose to ignore it.
Newstart2k
Prattville, AL
« Reply #4 on: July 11, 2019, 04:29:13 AM »
No special tools needed if you leave the forks on the bike and just replace seals. Total novice here. I took my time, did one side at a time, and had very little trouble.
« Reply #5 on: July 11, 2019, 06:09:33 AM »
Although I removed the forks from the bike to do mine, the one "special" tool you will need is a wrench slim enough to loosen/tighten the lock nut (#19) at the top of the right fork.  I found none of mine were slim enough, but then discovered the wrench in the OEM tool kit worked.  The videos Sandy mentioned were really helpful to me.  Just search "vtx 1800 fork seals" on YouTube and watch the four-part series by "brochscheller".
« Last Edit: July 11, 2019, 07:55:47 AM by Gryphon Rider » Logged
Bagger John - #3785
« Reply #6 on: July 11, 2019, 07:10:58 AM »
Another Tech thread got me down a forking rabbit hole, and this one is timely.
Looking at Find #7 in the diagram above...Tube (Outer) on the Valkyrie 'fiche shows as unavailable.
The VTX1800 part, on the other hand, is still listed. I'm pretty certain they're equal in length and in diameter, though someone with both bikes on-hand might verify this.
The internals are another matter. Several different dampers and rods (right and left fork tubes, respectively) are listed. Having owned and ridden an 1800-C, they're a heavy bike. Moreso the -S, -R and -N variants. Some of these models still list the fork internals as being available.
The question to the board at large: Has anyone played with various dampers in their forks to see how the ride is altered? Or is the better solution to hit Traxxion Dynamics up for a complete set of internals, should one wish to change the loading/damping characteristics?
Jruby38
Oxford Mass.
« Reply #7 on: July 11, 2019, 11:51:19 AM »
Thanks for the help. I want to the replace just the seals without removing the forks from top tree and messing with the springs. Do I need and special tools to do it this way and how do I add new oil?
Newstart2k
Prattville, AL
« Reply #8 on: July 12, 2019, 04:55:15 AM »
IMHO, you will want/need two good torque wrenches, a 45mm seal driver, a means to measure out fractional ounces of fork oil, a steady and relatively high motorcycle jack, plus all the needed sockets and allen head wrenches.
You definitely will want to have the info on torques, oil amounts,  and reassembly order that is in the repair manual and is generally available in some of the archives.
« Reply #9 on: July 12, 2019, 07:20:28 AM »
The extra trouble to remove the forks from the triple tree is not that much, and it helps to completely drain the old oil.  Better to buy or download a shop manual rather than rely on us remembering and typing out the "how to" information on this.  Also watch the YouTube videos I mentioned. There are two methods to know how much oil to add.  One involves removing the springs, requiring a special tool you can buy or make, then measuring a specific distance down to the oil level, and the other requires completely draining the old oil and precisely measuring how much new oil you put in.  I bought a graduated cylinder from a scientific supply company to use the second method.
A special tool that I forgot about earlier that is required, is a fork seal driver.  I made one from PVC pipe.
