December 31, 2025, 11:06:50 AM
Battery question
Topic: Battery question (Read 1262 times)
NighthawkVTX
Gainesville, Fl
Battery question
July 20, 2019, 08:34:44 AM »
I took my battery out the other day to do some maintainance. While it was out I took it inside and put it on my battery tender.
Sure enough I lost one of the little nuts that go under the terminal.
My first question. why are motorcycle batteries designed that way?
Second, can you use any nut to replace the one that is missing?
If at first you don't succeed, then perhaps skydiving isn't for you
Re: Battery question
July 20, 2019, 09:18:34 AM »
They use a nut underneath, because the soft lead terminals really can't be threaded; torquing, they'd just be stripped out with minimal pressure. Space is at a minimum, so they don't use car-style clamps going sideways.
You can use any nut that will fit under there and fit the screw. Most nuts are hex, the battery one is square.
You could walk the screw to the hardware/home depot and try to find one to fit. Maybe take the other square nut with you for comparrison. Any bike shop will have spares laying round.
One trick to getting the screw to thread into the nut at the bottom of the terminal underneath, is to squeeze a bit of foam rubber under the nut, to hold it up toward the top.
If shopping, buy a small tube of dielectric grease to use for the hookups. Though I've never had the chronic corrosion on my bike batteries like I have on my cars/trucks.
Here's your sizes:
https://www.amazon.com/Stainless-Motorcycle-Battery-Terminal-Scooter/dp/B07KHM174R/ref=asc_df_B07KHM174R/?tag=hyprod-20&linkCode=df0&hvadid=343796794064&hvpos=1o1&hvnetw=g&hvrand=14128095742310074756&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9008188&hvtargid=pla-710158687609&psc=1&tag=&ref=&adgrpid=69480722336&hvpone=&hvptwo=&hvadid=343796794064&hvpos=1o1&hvnetw=g&hvrand=14128095742310074756&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9008188&hvtargid=pla-710158687609
Last Edit: July 20, 2019, 09:23:55 AM by Jess from VA
9Ball
July 21, 2019, 05:55:58 AM »
If you still need them and can wait a couple of days I’ll send you 2 via first class mail.
PM me your address if you need them.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
NighthawkVTX
Gainesville, Fl
July 21, 2019, 07:00:07 AM »
Ahhhhhh one of the advantages of living close to daytona.. J&P cycles at destination daytona has a change out kit which includes washers and spacers
9Ball
July 21, 2019, 07:41:52 AM »
Quote from: NighthawkVTX on July 21, 2019, 07:00:07 AM
Good deal....except mine were free
1999 Standard
2007 Rocket 3
2005 VTX 1300S
=> InZane XXV
