Deerslayer
« on: July 23, 2019, 11:07:41 AM » |
So I hear a lot about guys doing a de-smog mod. Why is it done ? What’s the benefit?
Educate me please.
« Reply #1 on: July 23, 2019, 11:37:24 AM » |
I de-smogged. It de-clutters the motor, that is, it removes the pair valve and associated tubes and vacuum lines.
I've also helped replace the vacuum lines on an Interstate, it's not hard.
Fixing even small vacuum leaks will make your bike run better.
A desmogged bike might have fewer vacuum lines to go bad, but if you replace the vacuum lines with vacuum caps, you still have to keep track of whether or not the caps are leaking.
I doubt I'd desmog again if I got another Valkyrie.
-Mike "minority opinion"
nogrey
Nampa, Idaho
« Reply #2 on: July 23, 2019, 02:05:02 PM » |
I’ve de-smogged so many Valks I can’t remember how many. I’d say the biggest benefit (my opinion) is reliability. De-smogging removes: Pair Valves Vacuum control valve All but one vacuum line Re-breather port on air box Re-breather ports on heads (six). In addition, I always remove the 6 rubber fuel drain hoses (1 attached to each carb). Also, if you replace your petcock with a Pingle (or similar) manual, you eliminate all vacuum lines. You still have to cap each of the ports on the downdraft tubes, so those are still a failure item, but seems much easier to me to find a bad one.
The overall appearance of the engine block is so much cleaner and makes maintenance on the carbs less of a hassle (when removing, etc).
Just my opinion. Also, my description of each component may not be textbook.
Deerslayer
« Reply #3 on: July 23, 2019, 02:26:25 PM » |
Is there any difference in how the bike runs? What’s the job of the pair valve?
Just trying to learn as much as I can about these marvelous machines.
« Reply #4 on: July 23, 2019, 02:42:54 PM » |
No difference in how the bike runs, unless you happen to remove a vacuum leak while you're desmogging. https://www.moccsplace.com/images/pair/pair1.htm-Mike
WintrSol
« Reply #5 on: July 23, 2019, 03:35:26 PM » |
From the service manual: "EXHAUST EMISSION CONTROL SYSTEM (PULSE SECONDARY AIR INJECTION SYSTEM) The exhaust emission control system consists of a secondary sir supply system which introduces filtered air into the exhaust --- .) gases in the exhaust port. Fresh air is drawn into the exhaust port whenever there is a negative pressure pulse in the exhaust system. This charge of fresh air promotes burning of The unburned exhaust gases and changes a considerable amount of hydrocarbons and carbon monoxide into relatively harmless carbon dioxide and water vapor. This model has the pulse secondary air injection (PAIR) control valve and PAlR check valves. PAlR check valve prevents reverse air flow through the system. The PAIR control valve reacts to high intake manifold vacuum and will cut off the -. supply of fresh air during engine deceleration, thereby preventing afterburn in the exhaust system."
98 Honda Valkyrie GL1500CT Tourer Photo of my FIL Jack, in honor of his WWII service
« Reply #6 on: July 23, 2019, 03:37:22 PM » |
The PAIR valves use pulse vacuum to operate them. They pump air from the air cleaner box to the exhaust port immediately after the exhaust valve. The fresh oxygen provides air to complete combustion in the pipes and dilute the emission pollutants.
pancho
« Reply #7 on: July 23, 2019, 03:49:39 PM » |
I keep the "EXHAUST EMISSION CONTROL SYSTEM" on my bike maintained and in working order. It was designed for these bikes and has a purpose as outlined in the post above.
To just go in and rip it out over perceived future problems is like removing your wisdom teeth, appendix tonsils, prostrate, nuts and breasts out of fear they might go bad........... many do even though they all have a reason for being there.
« Reply #8 on: July 23, 2019, 04:06:46 PM » |
Yeah do tell why other than EPA guidelines that all that crap is there? Answer None.
« Reply #9 on: July 23, 2019, 04:27:05 PM » |
the bike will be three pounds lighter, so a little faster. more if a california bike with the canister.
« Last Edit: July 24, 2019, 05:50:47 AM by 98valk, (aka CA) »
Tfrank59
'98 Tourer
Western Washington
« Reply #10 on: July 23, 2019, 07:33:41 PM » |
Educate me please.
So you've read the pros and cons, as have I. I don't bother fixing what isn't broken or somehow diminishing performance, and my bike with the stock smog stuff (not a CA bike) is working great. As I've said to others making the same inquiry as yours, I have the desmog kit, so if something changes for the worse on my bike's performance (e.g. a vacuum leak), that's when I'll desmog it.
-Tom
Keep the rubber side down. USMC '78-'84 '98 Valkyrie, ‘02 VTX 1800, '96 Royal Star, '06 Drifter, '09 Bonneville, '10 KTM 530, '04 XR 650, '76 Bultaco, '81 CR 450, '78 GS 750...
« Reply #11 on: July 23, 2019, 07:53:38 PM » |
Educate me please.
), that's when I'll desmog it. ’ How wil this diminish your Performance? It is wil not.
« Reply #12 on: July 24, 2019, 04:25:59 AM » |
While we're on this subject, does anyone have a source for good quality vacuum caps? I was using BonS' for awhile there but I guess he is outta business.
« Reply #13 on: July 24, 2019, 04:38:59 AM » |
There's a couple of intake runners on a non-desmogged Valkyrie that are capped with studly OEM caps. I like those caps. The packs of flimsy vacuum caps at the auto-parts stores work for a while. You can unscrew the vacuum nipples from the intake runners and put in a small bolt of the right thread size, that'll plug your vacuum :-) ... -Mike
« Reply #14 on: July 24, 2019, 05:15:19 AM » |
redeye uses viton caps
Tfrank59
'98 Tourer
Western Washington
« Reply #15 on: July 24, 2019, 05:46:41 AM » |
Educate me please.
), that's when I'll desmog it. ’ How wil this diminish your Performance? It is wil not. a vaccum leak (which could be cured by desmogging) will diminish engine performance.
-Tom
RonW
« Reply #16 on: July 24, 2019, 07:56:23 AM » |
I used the oem plugs and they're quite sturdy. Though as Valkorado stated using a bolt which would be bulletproof.
2000 Valkyrie Tourer
« Reply #17 on: July 24, 2019, 08:33:32 AM » |
Actually that was hubcap's suggestion and I really want to do this. Has anyone done this and remember what size and thread of bolt will work? I guess it could be a PIA when synching but not so bad if old nipples saved?
« Reply #18 on: July 24, 2019, 09:18:23 AM » |
Actually that was hubcap's suggestion and I really want to do this. Has anyone done this and remember what size and thread of bolt will work? I guess it could be a PIA when synching but not so bad if old nipples saved? search should bring it up.
RonW
« Reply #19 on: July 24, 2019, 09:22:03 AM » |
Somebody must have tried this, as far as, the thread size and pitch.
« Reply #20 on: July 24, 2019, 10:14:33 AM » |
I haven't done it, but it seems like you could take out a nipple and run it down to ACE (or your favorite bolt place) and find a bolt with the right threads that isn't too long pretty easily. And you'd want the threads sealed too, I guess... RTV? -Mike
« Reply #21 on: July 24, 2019, 12:24:05 PM » |
I haven't done it, but it seems like you could take out a nipple and run it down to ACE (or your favorite bolt place) and find a bolt with the right threads that isn't too long pretty easily. And you'd want the threads sealed too, I guess... RTV?-Mike You don't want a permanent seal, but RTV won't take the heat (and just cook off). I'm thinking a hi heat medium-hold thread-locker (not red). Also, keep in mind the problems using different types of metals (with added heat) causes. But I'm here to tell you the cheapo auto parts vacuum caps don't last long at all. They heat up and blow off or blow in two very quickly. The push and pull forces put on them is significant (assuming you use the throttle).
« Last Edit: July 24, 2019, 12:28:40 PM by Jess from VA »
« Reply #22 on: July 24, 2019, 01:26:05 PM » |
but RTV won't take the heatI recently made the poor choice of coating my 8N's new manifold gasket with high-temp RTV...  I had to take my manifold back off, clean everything up (the rtv was still like rubber) and use only a new clean gasket on reassembly. I don't know if it is the appropriate stuff to seal the threads we're talking about with, but I bet it can handle intake heat... and it wouldn't be permanent. -Mike
Jersey
VRCC #37540
Southern Maryland
« Reply #23 on: July 24, 2019, 01:40:53 PM » |
On other jobs I've used a short piece of an appropriate sized hose and bolt to block vacuum ports. It looks like crap, but is very sturdy. Just use a bolt size that for sure seals the end of the hose.
Jersey
« Reply #24 on: July 24, 2019, 02:06:28 PM » |
Mike, I should have known RTV covered more products than the basic pure silicone stuff I use to glue things like my hand grips. I know THAT stuff can't take heat.
SPOFF
« Reply #25 on: July 28, 2019, 05:59:00 PM » |
I replaced all the caps including the OEMs with redeye caps and I replaced the vacuum line to the petcock.
Paladin528
« Reply #26 on: July 29, 2019, 04:54:58 AM » |
redeye sells good vacuum port covers.
