December 31, 2025, 11:06:48 AM *
Author Topic: Accessory Power  (Read 969 times)
« on: July 24, 2019, 04:18:59 AM »
Does anyone know where I can easily locate a power point that is only hot when the key is on?
I'm putting a voltmeter on my Interstate but I only want it to be hot when the key is on.
I'm concerned that if I wire it so that it is always on that it would eventually drain the battery.
« Reply #1 on: July 24, 2019, 04:59:15 AM »
The accessory hook up behind the right side side cover will work but the reading won’t be pure. A wire from the battery to the meter is the best way. What I did to avoid degrading that pure line was to wire a switch in line on the ground wire. This is helpful because you can turn it off once you kill the engine but you can switch it on to check the battery when the bike is not running. Turning on the ignition does not give a good battery reading because of lights and other stuff that gets power as well
« Reply #2 on: July 24, 2019, 08:20:00 AM »
Yep.  My Escort/Passport which functions as a voltmeter is wired direct to battery via the unswitched buss in the PC-8 panel, which has 10ga supply line from the dogbone.  Power not reduced by the other small loads on that buss - all of which have their own switching via other relays/triggers.  The radar is bright red and right in front of me - never forget to switch it off.  Quite accurate voltage readouts.  Very useful to keep me apprised of my power situation.  Not to mention cops.
