December 31, 2025, 10:55:17 AM *
Author Topic: 97 rear disc rotor  (Read 1231 times)
berto
« on: August 02, 2019, 04:01:29 PM »
Back with one more question Smiley Smiley Getting ready to swap the rear wheel as I got a nail to deal with.
Scored a straight high mileage wheel off of ebay from a 97 like my bike, the Avon tire on it is basically new and will be put to work but the bearing needed changing as well the rotor (5.2 mm).  replaced the left bearing with the double row one and sent the spacer to be machined, then after some reading, got me a rear rotor from a 92-02 ST1100 (looks identical 7.5mm $30 wow)     Now the question: the old rotor "inner diameter" is slightly bias toward the wheel, while the new one is perfectly straight  (!?!?)  Is the old rotor warped ???
did I buy the wrong rotor ?   if that... is shimming the solution ?   As always, many thanks to all
« Reply #1 on: August 02, 2019, 04:19:53 PM »
Using a non Valk or GW rotor puts it all up in the air. I'm not able to understand exactly what it is you are say. Pictures would be very helpful.
The year of rim/rotor need to match the right style (there is a range that works, but off hand, I don't know, search should find it).
There was a post about someone getting the rotor to work with the wrong rim and aligned to the caliper, and get it to work.
You can also add your location to your profile, and might get some local support to help out.
« Reply #2 on: August 02, 2019, 04:36:18 PM »
You need a rotor from a 97-99 Tourer/STD Valkyrie...
berto
« Reply #3 on: August 02, 2019, 05:05:51 PM »
My bike is a 97. The new wheel is from a 97. Did read on this board that the st-1100 and 97-99 valk share the same rear rotor.  To simplify the question...is the rotor supposed to be perfectly straight or slightly concave/convex ?   The old rotor is paper thin and I suspect is just warped
« Reply #4 on: August 02, 2019, 05:15:15 PM »
Parts fiche confirms that is so.
ridingron
Orlando
« Reply #5 on: August 03, 2019, 01:44:12 PM »
The exception is a '96 to '02 ABS rear wheel. The ABS system and wheels changed in '96. Not really a problem as the '96-'02 ABS wheels are pretty hard to find.
SCain
Rio Rancho, NM
« Reply #6 on: August 05, 2019, 06:11:55 AM »
You can use the 99 and up rotor on the 97 wheel (Rear), but it will require a shim to keep the rotor from scraping the caliper. A 1/32" to 1/16" washer will work just fine.
I believe the shim goes between the wheel spacer and caliper bracket.
Steve
« Reply #7 on: August 05, 2019, 07:38:17 AM »
rear rotor interchangeability.
HONDA ST 1100 Pan European L-Y,1 SC26 F440 Rear 1990-1992
HONDA ST 1100 Pan Europaen ABS-TCS AN,AP,AR,AS SC26 F440 1992 - 1995
HONDA VTX1800/VTX 1800C C1-CA8 SC46 e4*0113 Rear 02-09
HONDA VTX 1800F F SC46 e4*0113 Rear 2005-2011
HONDA VTX 1800N N SC46 e4*0113 Rear 2004-2011
HONDA VTX 1800R R1-R7 SC46 e4*0113 Rear 2002-2007
HONDA VTX 1800 S S1 SC46 e4*0113 Rear 2002-2007
HONDA VTX 1800T T SC46 e4*0113 Rear 2007-2011
HONDA ST 1300 A Pan European A2-A7 A8,A9-AA- SC51/e1/0147 2002-2013
HONDA ST 1300 P Pan European ABS P SC51 e1*0147 2005-2007
HONDA ST 1300 PA Pan European ABS PA PA8-9,A,B,C SC51 e1*0147 2006-2016
HONDA GL 1500 Goldwing L- SC22 E931 1990-2000
HONDA GL 1500 Goldwing A SC22 E931 1990-2000
HONDA GL 1500 Goldwing Interstate I 1990-2000
HONDA GL 1500 Goldwing SE SC22 E931 1990-2000
HONDA GL F6C VALKYRIE /GL 1500 Valkyrie C (SC34/H582) 1500CC 1997-2003
HONDA GL 1500 Valkyrie C /CD /CF (SC34/H582) 2000-2003
HONDA GL 1500 Valkyrie Interstate CI (SC34/H582) 2000-2003
HONDA GL 1500 Valkyrie Tourer CT SC34 H582 1997-1999
https://www.ebay.com/itm/Rear-Brake-Disc-Rotor-For-GL1500-Goldwing-90-00-Valkyrie-97-03-VTX-1800-ST1100/254220723218?hash=item3b30bc6412:g:h9YAAOSwdHhczm6J
berto
« Reply #8 on: August 10, 2019, 04:16:35 PM »
 Cheesy Cheesy Cheesy Finally had all the parts and the time to get at it.....”removing the rear wheel and installing a recondition one with the double row bearing on the left side”.   As it was the first time, lots of discoveries and plenty head scratching. The center stand and a small jack worked well enough.
First, i can confirm that a rear rotor from the ST1100 will fit the 97-99 rear wheel-caliper set-up.
Got it from eBay for $30 and 7.5mm (like new), plus a bottle of tequila to the guy that machined the spacer.
Followed all the great instructions mined from this awesome site till i got to trying to torque the 4 bolts on the rear drive....  tickedoff how do you get a torque wrench to fit close enough to make it work ????
Soo i just made sure they where nice & tight but would love to figure that one out.
Took the bike out for a 30 mins ride through neighborhood and everything seems ok.
Next Sunday bright & early will venture on the freeway “finger crossed”
