December 31, 2025, 10:55:19 AM
right rear blinker not working
Topic: right rear blinker not working (Read 946 times)
Funbaldguy
grand blanc Mi
August 12, 2019, 04:07:50 PM »
for some unknown reason my rear right blinker has stopped working. last Thursday I hooked up my trailer and started my pretrip light check. for some reason the right blinker on my bike was not working while the front and trailer lights are fine. since I was leaving the trailer on the whole trip I left, puzzled. bought a new bulb before meeting up with my friend. when replaced still not working. switched bulb to left and it works? now that I am home and taken the trailer off the light is still not working? bulb is fine. any ideas?
da prez
Wilmot Wi
Re: right rear blinker not working
August 12, 2019, 04:15:36 PM »
Basics , check ground and then use a good tester to check voltage at pin . If dead , go to the plug in under the fender.
da prez
Funbaldguy
grand blanc Mi
August 13, 2019, 02:54:28 PM »
Ok when I can find some time. Thanks
August 13, 2019, 03:52:41 PM »
I had a front blinker doing what your rear is doing. A good thorough cleaning of the turn signal switch fixed it.
=> InZane XXV
